Reading OBD1 Truck with OBD 2 Scanne
Old 04-08-2024, 03:34 PM
BobcatNT's Avatar
BobcatNT
BobcatNT is offline
I have a 1997 F 350, 460, seems to be an OBD 1 system. Getting Check Engine light after a short drive, oil pressure and temp are good. I did have an injector wire chewed off by rodents but it is fixed. I had an OBD 2 scanner. I ordered a cable to adapt OBD1 to OBD 2. No instructions, scanner says nothing when scan button is punched and ignition is on. Is there a way for this to work? I wondered if the OBD2 scanner would have the right software.
Old 04-08-2024, 03:50 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,179 Likes on 931 Posts
Most OBD-II scanners I have used do not have a battery to run them. They pull power from the OBD-II port. OBD-I does not have that function. Code data flow is also different for OBD-I versus OBD-II so a simple adapter is not going to work even if you rigged up a power source.
Old 04-08-2024, 05:21 PM
AuroraGirl's Avatar
AuroraGirl
AuroraGirl is offline
its a lot easier to just count the flashes. only a few high end tools from the 90s natively built in functionality for both back in the day during the transition OR the highest end tools today do both
bugeye01
12-21-2022 12:05 AM
Oilfieldtrash365
10-11-2020 05:16 AM
serpentine5
12-04-2012 09:49 PM
kwaskow
21
06-22-2010 11:41 AM
bred250
02-07-2003 06:28 PM
Quick Reply: Reading OBD1 Truck with OBD 2 Scanne
