1997 cruise control not working.
Old Apr 7, 2024 | 03:24 PM
Yankeetexan's Avatar
Yankeetexan
1st Gear
My abs light came on. I replaced the module and it still comes on randomly. Transmission shifts fine from first to second and second to third. But third to of the rpms are slot higher before it shifts and it doesn't seem like it shifts completely into od. My normal rpm at 65 is 2200, now it fluctuates between 2200 and 2400. All this stuff happened at the same time. So my cruise control doesn't work. I changed the transmission fluid and filter. The truck has 224,000 miles. I changed the rear differential oil 2 years ago. Any ideas would be greatly appreciated.
Jeff
Old Apr 8, 2024 | 08:25 AM
z31freakify's Avatar
z31freakify
Sounds like your torque converter is unlocking, could be bad wiring, burned out brake light, or in my case water being trapped in the trailer wiring plug.
Old Apr 10, 2024 | 07:40 PM
JWorley's Avatar
JWorley
First thing is to see if your third brake light bulb is blown. Mine had similar issues that were corrected with a new bulb(can’t believe I was lucky enough to have such a simple fix).
1ole4d
Nov 12, 2023 03:24 PM
Orlie
Feb 27, 2023 09:32 AM
Ecechowski
Jul 25, 2017 08:49 AM
Milwaukee1979F150
Sep 19, 2012 06:48 AM
trackenator
Sep 13, 2007 11:15 PM
