Engine identification
Old Apr 6, 2024 | 01:53 PM
triorez25's Avatar
triorez25
I recently pulled the motor from my 1984 f150. I know it's not the original motor since the vin claims it's a 351 windsor but the deck height is too low for that. The guy i bought the truck from said it was a 302, but I'm trying to confirm and hopefully figure out what year. I tried google but that went as expected. There's no shelf casted into the block by the starter and the bell housing area by the back of intake manifold is blank. I did find a casting number on the intake manifold itself, but that says it's a '78 351/400 modified which seems wrong since the bell housing is a windsor series not 385 series. Additionally the timing chain is not recessed in like the modified. So is there somewhere else i can find the date info? The Manifold says "D8AE"
Old Apr 6, 2024 | 07:13 PM
85e150's Avatar
85e150
How many valve cover bolts?
  1. 2 bolts: 239/256/272/292/312 (produced from 1954 to 1964)
  2. 5 bolts: 332/352/360/361/390/391/406/410/427/428 (FE engine)
  3. 6 bolts: 221/260/289/302/351W.
  4. 7 bolts: 429/460.
  5. 8 bolts: 351C/351M/400.
Old Apr 6, 2024 | 08:01 PM
triorez25's Avatar
triorez25
6 bolts. Alright now I'm even more confused why the manifold says it's a modified
Old Apr 6, 2024 | 08:32 PM
85e150's Avatar
85e150
All "D8AE" means is 1978 full size car line, Engine engineering group.
Post 9 shows the water pump/deck relationship for both 302 and 351W.
https://www.jalopyjournal.com/forum/...or-351.963521/
302 and 351W valve covers are /==\, vs. (==) for most other engines.
Old Apr 6, 2024 | 09:00 PM
triorez25's Avatar
triorez25
ok my bad the site i was using made it out that only modified engines had that code. And the water pump is at the top of deck so i guess it's a 78 302
Old Apr 6, 2024 | 09:07 PM
85e150's Avatar
85e150
D8 for 1978 is a revision date on the casting. The casting could have been used for a few years after '78. Theres a date code down by the starter area if you really must know.
Does it run ok?
'78 was still a dark year for power for all engines. Mid to late '80s the roller cams started to show up etc.
You probably know all that.....
If it comes to upgrading or replacing, there's plenty of info here on what to look for to get into the 200s+ for HP for very little effort beyond the basics. Ditto the 351W as to roller cams.
Old Apr 6, 2024 | 10:30 PM
Conanski's Avatar
Conanski
The easy button on identification is to simply post a picture of the engine, that is the best way to ID any Ford motor.
Old Apr 6, 2024 | 10:52 PM
triorez25's Avatar
triorez25
Does it run ok?
i think i'm satisfied. it ran but drank oil, i'd drive it for 15 minutes and need a gallon of oil, but it was fine idling. so i got a 97 f250 with a 351w i'm gonna put in there, swap it back to carburetor the works. I plan to put new heads and a cam in eventually for now i'm focusing on getting it running
triorez25's Avatar
triorez25
fair my bad
neatocj
Aug 5, 2011 07:39 AM
jerm111
Aug 11, 2010 11:26 PM
79outlawf150
May 7, 2010 06:34 AM
glanzer_51
Jun 11, 2007 12:59 AM
samahi72
Dec 14, 2004 05:09 PM
