Sand blasting
Old Apr 6, 2024 | 08:37 AM
64f1002017's Avatar
64f1002017
Sand blasting
Does anyone use sand for sand Blasting? On my sand blaster I just purchased it says do not use sand. It says use blasting media instead which cost a lot more than sand. I have over 40 years in the paint and body repair field although it has been many years since I sand blasted we used to use silca sand to blast with. It worked great. I am thinking it says not to use sand to try and force you to buy their expensive blast media.
Old Apr 6, 2024 | 08:52 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Sand is OK but it often contains Crystalline Silica which is made up quartz and cristobalite which are both carcinogens and are both in Asbestos. Use good respiratory protection when using it. Silicosis is a real thing. Just know that there are safer forms of blasting media like glass bead, soda, etc.
Old Apr 6, 2024 | 08:55 AM
BarnieTrk's Avatar
BarnieTrk
There are other, safer blasting medias to use other than sand. Cost and how fast it cuts are decision factors as well as different mesh sizes. Silica sand works, but it can be dusty which can cause Silicosis. The last items I had blasted were a set of wheels, which were blasted with black slag, 'Black Beauty' media. It worked well. Wallnut shells, baking soda, aluminum oxide, are other medias to decide between. Some claim to not be as aggressive with glass, rubber moulding, etc. than silica. Issues to watch for are contaminants, lumps, and moisture. Be sure to screen your choice of media when you load your blaster. Eastwood Automotive Group has a good selection of blasting gear & accessories.
BarnieTrk
Old Apr 6, 2024 | 09:00 AM
Crop Duster's Avatar
Crop Duster
Lately I've been using re-cycled ground glass. I get it at Northern Tool. Or you can get different grades of sand at any large rental place that rents sandblasting equipment.
And if you have 40 years breathing body filler dust I wouldn't worry about a little sandblasting.
Old Apr 6, 2024 | 09:23 AM
52 Merc's Avatar
52 Merc
None of this stuff is good for you and all will cause lung damage, so take care of yourself. To say that one is better for you or choose a type of media over another because it's safer is a fools game. Wear full body protection whatever you use.
When sandblasting automotive body parts in restoration shops, we used 70 silica sand as it was fine enough not to leave pits and surface damage, but harsh enough to do the job. Just still be mindful of heat and panel warpage.
Old Apr 6, 2024 | 08:32 PM
john jamieson's Avatar
john jamieson
If you want to cut down on the dust, look into blasting with dry ice pellets.
Old Apr 10, 2024 | 05:28 AM
BC_99's Avatar
BC_99
I used coal slag from tractor supply. $11/bag. Cuts good, but not too deep.
BC
Old Apr 10, 2024 | 06:16 AM
casetruck1's Avatar
casetruck1
I blasted my whole truck with black beauty. We tried sand and black beauty but we had the best luck with the black beauty. Had to get the finer grade to get it to sift into the blaster. I had the luxury to have a concrete apron outside of the garage and I also threw a lumber tarp out and swept and sifted each blaster full back up and sifted back into it. Usually got 2 sometimes 3 uses out of the hopper before it turns to dust. I had the blasting hood that I used and wish I had worn respirator also. I was a teenager then and I was young and dumb.
Old Apr 10, 2024 | 06:41 AM
charlie g's Avatar
charlie g
FTE Community Team
BC
DITO . but it's now $12.99 a bag and worth every penny . the fine leaves the metal smooth the course you going to be laying down several coats of primer
Old Apr 10, 2024 | 08:04 PM
BC_99's Avatar
BC_99
Great point. I should have mentioned that… I used the fine as well. The coarse stuff absolutely cut too deep and left a rough texture and clogged up the blaster pretty quickly. The fine grit worked really well with no clogging.
BC
Old Apr 10, 2024 | 09:00 PM
theastronaut's Avatar
theastronaut
Sand will permanently ruin your lungs in a hurry, the warning label is not just to get you to buy something else. Use coal slag or crushed glass, and a respirator style filter that seals to your face 100%. The dust is not something to play around with.
Old Apr 11, 2024 | 05:58 AM
charlie g's Avatar
charlie g
FTE Community Team
anyone with smarts knows to wear a hood and a good face mask, one big error is not having enough compressor to handle the job,
macs40
Paint & Bodywork
Jun 3, 2016 02:16 PM
Snipeston
Paint & Bodywork
Jul 4, 2014 05:53 PM
frankensteined_67
Paint & Bodywork
May 4, 2009 12:02 PM
FordFadgeole
Paint & Bodywork
Jan 24, 2004 06:23 AM
elwood
Paint & Bodywork
Jul 15, 2003 11:21 PM
