2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
2017 pan gasket leaking
Old Apr 2, 2024 | 10:16 PM
rexpedition99's Avatar
rexpedition99
I just bought a 2017 expedition in the previous owner had put RTV sealant on the transmission pan gasket. While fixing the molded lead frame, I scraped off all the old RTV sealant and bought a brand new pan gasket. In the gasket instructions it said to tighten bolts to 80-in pounds, however, the pan started leaking slowly around the gasket after ftlling. I'm wondering if I should have tightened it to 98 in pounds which is the spec I saw on a YouTube video. Does anyone have the pan bolt torque specs for a 2017 expedition?
Old Apr 3, 2024 | 09:16 AM
rexpedition99
For example in FordTechMakuloco Molded Lead Frame video, he says 98 in-lbs, ford-specs.com says 10 ft-lbs (120 in-lbs), and the paper that came with the new gasket says 80 in-lbs.
Old Apr 7, 2024 | 09:05 PM
rexpedition99
FYI, for anyone else needing the info, it appears 80 in-lbs worked after I drove the truck a little, the gasket seems to have sealed.
Homerunking2394
Feb 12, 2018 12:55 PM
aclaybor
Apr 5, 2015 11:43 PM
gthbryce
15
Apr 20, 2009 11:53 PM
eandaauto
Jun 4, 2004 12:19 AM
pward76
Garage & Workshop
Jan 31, 2003 03:13 PM
