Hi all. My f250 has a 390 and Motorcraft 2v.C6. I am feeling a vibration through the gas pedal when I hold speed starting at 20mph. Shifting to NUETRAL the engine roughness feeling stops.
Its prgressed to a miss at idle that I feela on acceleration on hills.
The spark plugs, Pertronic full billet distributor and its cap, along with taylor. 8mm ignition wires were done 14k miles ago.
My engine has a fairly substantial rear seal oil leak
So I dont know if Im burning oil.
So its probably time for a wet & dry compression test and a leak down test...to see what's what...correct?
Compression test is a good idea, and a in cab mounted vacuum gauge sure would help in the future. Feeling vibrations in the gas pedal could be just linkage too near something. You asked about a failing cam .... I think likely not. A miss at idle that you can feel during acceleration on hills is likeliest ignition related, like plugs or wires. I don't know Pertronic.
The cam is an unlikely cause on a well used engine, your crappy distributor is more likely it. but a bent push rod, bad lifter or valve can cause a similar effect.
Check your plugs and see if they're all firing. check your timing and for vacuum leaks. if everything checks out do a compression check.
i have a couple of vacuum guages...i could run a vacuum hose into the cab and connect up one of those gauges...
Have you checked your u-joints and engine and transmission mounts?
I have not checked either of those yet. The transmission mount is likely bad. I have oil coating the chassis the rear main seal leak . This truck had 58000 miles on it when I bought it in 2018. The only other owner kept a gas mileage journal and a maintenance journal on old fashioned spiral note books the truck has 86k miles now. I have employed the grease gun on all the zurk fittings a few times since 2017. I ll look at u joints...I just presumed them ok due to the P/O being so dillegent with his own grease gun regiment.
That rear seal needs to be replaced...the truck sat undriven in the driveway for 6 years with its huge 50 year old camper on it while the P/O slowly died...likely that inactivity did the rear main seal in.
thanks...the engine is just turning its FIRST 87K miles. Until 10 years ago it had 2 oil changes per year. Then the only other owner got ill and that type of "its my baby" maintenance stopped. It had 58k on it when I got it. I have pretty locked down mileage verification. Gas mileage journal from new. Maintenance and repair journal since new some s very faded but its there to read.
He took this truck from San Diego to Idaho and back most years on a hunting trip. Its huge cab over camper kept it driveway bound except for every v 12 weeks for a drive to his work.
I had to replace the in cab gas tank,fuel pump and have the motorcraft 2v carburetor rebuilt due to bad gasoline in 2018 when it became mine. It has 87k now.
