Mississippi Chapter Join Chapter , Leader: Scndsin
April BS Thread
Old Apr 15, 2024 | 07:27 AM
Scndsin's Avatar
Scndsin
That's beautiful. I have no idea the actual purpose of the seal, other than maybe dust or dirt.
I'm sure you recognized the material as just that kind of open cell foam you see in packing stuff & lawn-mower engine air filters.
Old Apr 15, 2024 | 10:02 AM
56panelford's Avatar
56panelford
Ordered a roll of the stuff that was cheaper than that gasket I had posted..hoping to give the motor a bath today then see how things go from there...lol
Old Apr 17, 2024 | 06:02 PM
56panelford
My bracket and pump arrived and got the bracket cleaned up. Wondering if the pump could be good to use as it is after I get it cleaned up and repainted
or should I replace it. I'll need a reducer valve because I'm running a rack and pinion..
Old Apr 18, 2024 | 07:25 AM
Scndsin's Avatar
Scndsin
I've never opened up a "canned ham" pump, but have been told they're pretty easy to rebuild effectively if you can get a quality kit.
Maybe just a clean up inside will do the trick if the wear is not bad.
I hear a fluid filter is a good investment for them, but don't know much about sourcing one.
Old Apr 18, 2024 | 08:09 AM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
They are simple to rebuild and the kit is cheap (less than $20) Took mine apart, cleaned with brake clean and put it back together with the kit in less than an hour.
Old Apr 18, 2024 | 09:31 AM
56panelford
I guess I can always take it a part to see if any metal parts are worn before buying a kit. Worse case scenario would be to buy a new pump ...pressure valves are $32 US to reduce the pressure to 850 psi for the rack..
Old Apr 18, 2024 | 01:10 PM
f1504x4driver
Proud Pirate
It is definately worth the effort.
Old Apr 18, 2024 | 01:54 PM
56panelford
New pumps are pretty expensive , this whole damn project has been...lol
Old Apr 18, 2024 | 06:13 PM
56panelford
Ordered a rebuild kit off Amazon and should have it by next Friday..
Old Apr 19, 2024 | 10:48 AM
f1504x4driver
Proud Pirate
Cant wait to see the progress!
Old Apr 19, 2024 | 01:56 PM
56panelford
We had a good day where I could have taken the engine outside to scrub it good and rise it out but got side tracked doing other stuff and now we keep getting these freak snow storms preventing me working outside. Hopefully next week, I'd like to start assembling the engine..
Old Apr 25, 2024 | 05:15 PM
56panelford
Well washed out the engine today and wiped it as clean as I could and then sprayed it with WD40 and slid a garbage bag over it. Fun not knowing what I'm doing...lol
Old Apr 25, 2024 | 05:45 PM
  #28
f1504x4driver
Proud Pirate
Welcome to my world...
Old Apr 26, 2024 | 02:07 PM
  #29
Scndsin's Avatar
Scndsin
So today it's generic viagra commercial ...
Somewhere in the middle of all the yadda-yadda, it penetrates my mind:
"...and tell us why you NEED IT..."
Old Apr 27, 2024 | 04:50 PM
  #30
56panelford
Well I cleaned up that Saginaw pump and put a kit in it. didn't look as though there was any wear in it but sure was dirty inside the reservoir and dirty metal sludge covering the magnet . I won't know how good of a job I did until I get this thing up and running..what ever year that ends up being..lol
