Lost wireless CarPlay
Old Mar 30, 2024 | 08:04 AM
Poncho450's Avatar
Poncho450
2023 F350 with SYNC 4 12 inch display. Apple CarPlay has always connected wirelessly with no problem. This morning it suddenly will not connect unless plugged into the USB port.
I’ve removed the truck from the Bluetooth settings in the phone, removed the phone from the truck head unit and started fresh, re-pairing everything. CarPlay is enabled on the phone. Latest iOS installed. SYNC version 23163. Revision 917.
The head unit seems to recognize the phone as far as making or receiving calls. But no CarPlay.
Suggestions, tips or tricks anyone?
Old Mar 30, 2024 | 09:29 AM
Poncho450's Avatar
Poncho450
The good news: it’s working again.
The other news: no idea why.
On the 10 mile drive home from breakfast this morning it would not connect. After messing with it in the driveway as stated in the first post and not having any luck I just walked away from it.
A half hour later I started the truck, began driving down the road and I had wireless CarPlay again.
Old Mar 30, 2024 | 10:37 AM
Kameron Rice's Avatar
Kameron Rice
my f450 had a hell of a time connecting yesterday as well. I deleted the phone, but I couldn’t even get it back to the add phone screen, it wouldn’t open up when I clicked the button. Tried 4 times throughout the day. Last night it started working. I just got an over the air update and wondering if that had something to do with it.
my F350 has never received and update since I left the dealership (update button is on, I guess it just doesn’t have connection), I think I am going to turn the bottoms off in both trucks, don’t trust ford.
Old Mar 30, 2024 | 10:47 AM
Poncho450's Avatar
Poncho450
I could add the phone back after deleting with no problems. CarPlay just didn’t want to go along.
Pretty sure I’ve had no updates. I’m on vacation and the rental home’s Wi-Fi network has not been added to the truck.
I don’t get it. But it seems to be OK again.
Old Mar 30, 2024 | 02:51 PM
Fox-BLUE1's Avatar
Fox-BLUE1
This happened to me about 2 months ago. I took the fifth wheel out and when I started the truck to start the trip it would’t connect. Had to use a USB cable for pretty much the entire trip. Since then it’s worked with no issues and I don’t know why that trip it acted up.
Old Mar 30, 2024 | 03:14 PM
andrew8406's Avatar
andrew8406
Sometimes a reset helps. When you turn off your truck, your radio just sleeps for the most part. I believe it’s holding power and track skip will cause your radio to reboot. If that doesn’t work, then try to reboot your phone. Beyond that, you’re into re-pairing and such. If I ever have any problems with this kind of stuff, this fixes it 90% of the time.
Old Mar 30, 2024 | 03:23 PM
Fox-BLUE1's Avatar
Fox-BLUE1
Yeah I tried both of those. Rebooted phone, rebooted radio, turned truck off and on. When I would hit a stop light I would try and reconnect CarPlay and nothing. Super annoying. It was only that trip though. Since then all good!
Old Mar 31, 2024 | 06:38 AM
Poncho450's Avatar
Poncho450
I guess the only thing I didn’t do was a soft reset. If it happens again I’ll try that. Rebooting the phone, removing the phone from SYNC and removing the truck from the phone and pairing them anew didn’t work this time.
A mystery that I’m glad to not be trying to still solve.
Old Mar 31, 2024 | 07:11 AM
sbechtold's Avatar
sbechtold
When I first got my truck (MY24 F350), Android Auto would randomly disconnect in the middle of a drive. The only thing that makes it work again, during the drive, is plugging in the USB cable. Most of the time the problem would go away after the truck is parked overnight. A few times the issue persisted for a day or two before going away. I haven't had this problem happen in a few months now.
Old Mar 31, 2024 | 09:36 AM
CascadeF250's Avatar
CascadeF250
I am having the same trouble. I did all of the things that you have done and car play still is not consistent. There was a ford update on the system in my truck just before I left for a trip and CarPlay has not worked the same since . I have found sometimes the only way that I can get it to work is to turn off CarPlay and back on and then it hooks up right away. It’s inconsistent. Sometimes when I get in the truck to go, it works and other times it doesn’t. Likely blame Ford for their last system update on my truck. My phone is a iPhone, that has the latest operating system in it. Hopefully this problem will fix itself eventually when ford messes with my truck again. this is very annoying when you are navigating by Apple Maps.
Old Mar 31, 2024 | 09:46 AM
Quad Racer's Avatar
Quad Racer
I have intermittent issues with my CarPlay. Usually when my wife and I ride together. If she turns off her Bluetooth til my phone connects that helps.
Old Mar 31, 2024 | 05:24 PM
jackfordsd350's Avatar
jackfordsd350
My 22 450 also had a similar issue during our trip today. This was android auto and the same thing was happening. Waze also was not operating. After a fuel stop it started to get back to work. After that it all worked fine. No recent update.
Sous
894
Jul 16, 2025 03:13 PM
tkoden
Oct 1, 2016 05:36 PM
High Intentions
Mar 2, 2010 07:00 AM
