I'm lost, rough running
Old Mar 27, 2024 | 09:13 PM
Dante Brown's Avatar
Dante Brown
Trailering
So I have a 1995 f150 302 4x4 obd 1 and I have codes 565 10 (hold code or something like that) then 173 I replaced O2 sensor didn't fix it iv done plugs, wires, pick up coil, cap, rotor, new O2 sensor pig tail, ignition coil, ignition control module still nothing. When I have the O2 sensor plugged in the truck runs like dog**** if I have it unplugged truck runs pretty good but definitely runs rich. Then I also have this weird rattling sound best I can explain the sound as but it happens when I'm almost out of over drive you can hear it and it gets louder the closer to being out of that gear. If anyone can point me in any direction I'm lost
Old Mar 28, 2024 | 05:33 AM
Mudsport96's Avatar
Mudsport96
Had something similar and changed O2 sensor twice and map sensor. Then finally the correct code tripped for the Incoming Air Temp sensor. Pull that out of the intake and clean it off and put it back in. See if that helps, or just replace it.
For the 565, you are probably sucking charcoal out of the canister. It just fiddled with the solenoid valve till it closed, and put a cheap lawnmower fuel filter between the canister and valve to catch debris.
86Bronc302
1978 - 1996 Big Bronco
15
Apr 7, 2023 10:01 AM
RacinNdrummin
Sep 16, 2006 06:45 PM
motocam25
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
21
Jan 5, 2005 09:39 AM
bsour
Aug 19, 2004 03:11 PM
flintster
Jan 29, 2004 11:13 PM
