Question about lifting my OBS
Old Mar 26, 2024 | 10:57 AM
Eminem1111111111111's Avatar
Eminem1111111111111
So I recently bought a 1992 ford f250 4x4 that I want to lift and put 37s on. But I’m also planning and swapping the front TTB for a solid Dana 60, and a lot of lifts I see say IFS only on them. Is that really that big of a deal? And if so, does anyone know a good lift that would work for me? It has the towing package if that changes anything
Old Mar 26, 2024 | 12:25 PM
JJF20's Avatar
JJF20
Look for F350 lift kits..
There are a lot of options and pre-fab kits for this, and different ways of doing it.
Id also suggest reading up as many build threads as you can, get a good handle on it first. Lots of build threads out there and people who’ve done it.
Don’t forget gearing.
Old Mar 26, 2024 | 04:14 PM
Edgethis's Avatar
Edgethis
As mentioned, super easy to lift if you're already planning to do a d60 swap. With a D60 front your suspension would be identical to an F350, more or less
Get the axle, do an rsk and those will have options for lifts, theb get some comfy SD springs and the fronts done. Get some fresh rear springs and a F350 block and the rears probably good to go too.
The kits are all going to say ifs only since the F250 pretty much only came with the TTB D50 ifs. But some people think leaf spring front is same same between F250 and F350, so that's why the disclaimers there.
Old Mar 26, 2024 | 06:40 PM
Eminem1111111111111
Thank y’all, this helps a lot
TexasPowerstroke96
16
Jan 8, 2015 10:46 PM
crazer42
Dec 5, 2011 03:11 PM
rmalottwtes30
Nov 20, 2008 09:12 PM
DrJekyl5
Sep 28, 2005 05:03 AM
