Under da Cab
Old Mar 26, 2024 | 09:47 AM
stylesidetruckguy's Avatar
stylesidetruckguy
Trailering
Under da Cab
I just finished painting the firewall on my dentside build to test the color (2-B Red 1k) and it came out great.
For the underbody of the cab would like to go with a durable paint/coating that will hold up for years to come. I want to do the job right rather than cheap and have since been doing research. Rubberized coating sounds like a pita with moisture getting caught so I would preferably not use it unless otherwise highly advised to do so from others. Even then I have seen the effects of a poor application.
I was thinking something like matte por 15 or the like. The tar on the bottom is completely dried up so if there is an alt to that too that would be great.
Any and all advice is welcome as far as applicable.
Thank you.
Old Mar 26, 2024 | 10:28 AM
tbear853's Avatar
tbear853
What is the intended use? Show or Go or Show & Go? I think a thorough cleaning, de-rusting, priming, & paint is the best start.
After that, then decide whether appearance or durability is most important. Under coatings will dry up and often "let go" in time. Metal or polyurethane type shielding can protect from splash wear and damage over long periods, but purists will look down on them..
Just my view.
Old Mar 26, 2024 | 11:07 AM
stylesidetruckguy
Trailering
It will be a go truck. Looking for more durability than anything. If I prime and paint now, some dtm solutions might be affected.
Yes I have seen how bad certain undercoating turn after time. It is some hateful stuff. Fingernail can scrape em off after time.
Old Mar 26, 2024 | 11:22 AM
tbear853's Avatar
tbear853
https://www.ford-trucks.com/forums/1...ispreloading=1, See my post #1932, it is fairly recent. It suits me well.
speakerfritz
Paint & Bodywork
Mar 7, 2019 05:43 PM
CharlieLed
Jul 22, 2011 12:09 PM
caelmalu
18
Jul 16, 2010 11:14 PM
Scolesy8
Paint & Bodywork
Jan 27, 2009 10:05 PM
horton-racing
Paint & Bodywork
Jul 13, 2004 03:05 PM
