Exploded rear bearing
Old Mar 25, 2024 | 07:00 PM
Vanhartman's Avatar
Vanhartman
I had a bearing go out on me a couple months ago and life got in the way so I’m just now addressing it, as I was going to replace the bearings, I noticed that something was still stuck in there, I assume the outer ring of the bearing. No matter what it is it’s got to go (see second photo for how it SHOULD look, as shown by the passenger side) I was thinking of using some gear pullers, those type with the three prongs, but then I realized that the prongs don’t grip in the outward direction, so I don’t think that would be too effective, unless they could somehow hold on to those thin layers shown in photo one. If y’all have experienced this or have any advice it would be much appreciated, any help is appreciated, thanks.
The troubled side, note the interior ridges and lip, both feature not on the non-exploded side
The correct, non-exploded side
Old Mar 25, 2024 | 07:03 PM
85e150's Avatar
85e150
Some pullers allow you to reverse the prongs to be inside or outside.
A slide hammer might help.
You can make one out of a long bolt or threaded rod, washers and nuts and length of pipe short that fits over the bolt.
Old Mar 25, 2024 | 08:57 PM
fivestarmmd's Avatar
fivestarmmd
Weld a bead around the inside and it will practically fall out
Old Mar 26, 2024 | 04:28 AM
'65Ford's Avatar
'65Ford
A slide hammer with the pullers reversed will remove the bearing remnant easy enough. Some parts stores loan tools like slide hammers...or they used to do that.
That sure is a nasty, gummed up hub...wow that is nasty.
Please use a better support than a scissors jack...even brand new those are rickety. Jack stands are nice though I often use solid 6x6 wood blocks.
egchewy
19
Nov 18, 2022 01:56 PM
Patina65
Mar 15, 2022 06:32 PM
PRIMERED79 SHORT BED
Dec 15, 2021 12:06 PM
Bsta0302
13
Aug 11, 2020 05:28 AM
1988F-150
Sep 26, 2009 06:42 PM
