Sponsored by: Real Truck
What is this?
Old Mar 22, 2024 | 08:09 PM
Pecosbill7's Avatar
Pecosbill7
What is this?
I was inspecting the front end because, once again, its death wobble time. I found what appears to be two seals, one on either side, that aren't attached to anything. They're located just inside behind the brake rotors. I don't even know what this part is called. It's not a ball joint or any other linkage with which I'm familiar. They are both loose and just flop around. Is it something that should be replaced? How big a job is it? Thanks. Bill
This just flops around loosely, whatever it is.
Some sort of grease seal?
Old Mar 22, 2024 | 11:04 PM
cj45lc's Avatar
cj45lc
Those are just dust seals at the end of the axle tube, the oil seal is further inboard. You would have to pull the hub & axle to replace them.
I'd be more concerned about the death wobble.
Old Mar 23, 2024 | 10:23 AM
Pecosbill7's Avatar
Pecosbill7
Thanks. Seems like it would be pretty involved to replace them for little benefit.
On the death wobble, this is the third time I’ve had to address it. 2008 F250 King Ranch. First two times it was the track bar that needed to be replaced. This time I’m not so sure, as the track bar seems pretty tight. Does anyone make a replacement track bar that has grease fittings on it that might wear better? Same with the ball joints.
AuF250
Sep 29, 2021 06:38 AM
lasermike
Jun 16, 2017 12:59 PM
Djstright
Dec 1, 2016 01:29 PM
ShawnV
Jun 6, 2014 01:16 PM
Zanewm
May 29, 2006 06:04 PM
