starting issue
Old Mar 21, 2024 | 11:59 AM
RBROWER's Avatar
RBROWER
1st Gear
Unhappy starting issue
hi there and thanks for any help you can give--2004 f150 with a 4.6l --- just changed the fuel pump, plugs, injector and coil packs and i now have an issue that i cannot resolve, here goes--- so in the morning i can start it just fine and drive it--but after shutting it off it doesn't always want to start back up( i can shoot it with ether and it starts and runs fine) or if i wait 1-2 hrs. it will start back up and run fine .
there are no codes and the snapon test computer shows nothing wrong---any clues would be helpful---thanks
Old Mar 23, 2024 | 05:30 PM
getterdun1's Avatar
getterdun1
Sounds like a "closed loop" problem. That's when the PCM starts using various sensors to moderate the air/fuel mixture. If your OBD tool reads sensors, check the 02, temp, and fuel pressure sensors as well as fuel trims. Show us and we may be able to help.
Old Mar 24, 2024 | 07:38 AM
techrep's Avatar
techrep
Have you checked the condition of your Fuel Pump Driver Module?
forrestblade
Oct 12, 2023 10:42 AM
perplexd
2009 - 2014 F150
Aug 3, 2021 05:49 PM
Raycer 27
Apr 18, 2021 08:09 AM
Bowtie95
Sep 2, 2012 01:25 AM
trucking87
May 13, 2005 09:44 AM
