COM Trans oil pan
Old Mar 21, 2024 | 10:51 AM
Dodgeyaussie's Avatar
Dodgeyaussie
COM Trans oil pan
Anyone had any luck sourcing a new oil pan for the COM? Seems to be plenty for the C4/C6.
Old Mar 21, 2024 | 01:43 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The C4 and C6 are of course newer and much more popular. The MX Cruise-O-Matic has its roots in the Ford-O-Matic which was introduced in 1951. The oil pan for the MX is part number.
B5SZ-7A194-A - PAN ASSY. - OIL
The B5 means it was first used in 1955. The Thunderbird and certain large Ford cars used the MX-COM in some of them. But even then, nobody seems to be reproducing it for those cars, either. At least that I could find. A good used pan is likely the best option if yours has issues.
13 1/8" x 10 15/32" / 14 trans pan bolt holes.
Fits '55/57 T-Bird / '56/57 Station Wagons with 292 4V's and 312's / all big (MX) Cruiseomatics 1958/67.
Old Mar 21, 2024 | 01:50 PM
Dodgeyaussie
Thanks for the info. It looks like some clown used it as a jacking point at some time, without a block of wood, so it's a little pushed in, in a couple of spots, which may be contributing to it leaking from distorting the whole pan.
Old Mar 21, 2024 | 06:36 PM
AZSCAWPION's Avatar
AZSCAWPION
Unless crushed you should be able to flatten with an anvil or some flat surface. Same for the flange. Will probably be easier than trying to source replacement.
As far as it leaking, they're supposed to. If it stops leaking you know you have to add fluid
speakerfritz
6.7L Power Stroke Diesel
20
Jul 7, 2022 10:09 AM
Dually02
May 9, 2006 09:42 PM
