Paint work with rustoleum
Old Mar 18, 2024 | 08:48 PM
Tobey Anderson's Avatar
Tobey Anderson
4wd High
I am repainting my truck and got it all done and then pulled tape off for my two tone line and it ripped all the paint off under the tape. I was wondering if I had done anything wrong, I apply old 55 self etching primer to the bare metal then applied old 55 sandble gray primer sanded at 1,000 grit then started on paint. In-between each layer I sanded at 1,000 grit. Please help what did I do wrong.
Old Mar 18, 2024 | 09:15 PM
Junktownbill99's Avatar
Junktownbill99
What the hell kinda tape were you using??? To rip the paint off should take some serious force, unless yours was still wet and not bonded properly ​​​​
That's about the extent of my paint knowledge, hopefully the paint guys can take over.
Old Mar 19, 2024 | 01:06 AM
Soup bean's Avatar
Soup bean
I'm not a professional.
I use 3M Adhesive Remover before primer on bare metal.
Bare metal needs to be sanded before primer is applied.
Primer won't stick to smooth metal.
The way I understand it, bare metal gets sanded, then use a tack cloth, then wipe it down with something like 3M Adhesive Remover.
In order for paint to stick to primer, you either need to paint after the primer flashes off or if you wait too long, you need to sand, tack cloth and wipe down with something like 3M Adhesive Remover.
Temperature and humidity affect everything.
Follow the manufacturers directions to the T.
Here's the best painting video I've ever found
Old Mar 19, 2024 | 04:10 AM
AuroraGirl's Avatar
AuroraGirl
rustoleum isnt the best paint for the exterior paint of a vehicle, but its not bad either, what kind of rustoleum top coat you using? Show us hte damage
Old Mar 19, 2024 | 05:36 AM
GNR22's Avatar
GNR22
It sounds like the paint had not cured properly, or did not adhere properly from surface contamination. Without seeing your process, hard to narrow down the exact issue, unfortunately.
Old Mar 19, 2024 | 05:46 AM
charlie g's Avatar
charlie g
FTE Community Team
all of the above plus that one word RUSTOLEUM, right primers wrong paint,
Old Mar 19, 2024 | 06:39 AM
tjc transport's Avatar
tjc transport
i ain't rite
to use rustoleum paint, you also should use rustoleum red oxide primer.
Old Mar 19, 2024 | 09:55 AM
McLeod's Avatar
McLeod
1000 grit is too fine - probably not enough tooth for paint to bite into.
Single stage is usually good at 320/400 range and 2 stage (base/clear) is usually good at 500/600 range
Wax and grease remover is also needed to help with a clean bonding surface. Also rubbing alcohol works and some have good luck with windex etc but I have no experience with that.
Would also recommend automotive refinishing tapes instead of hardware store general duty tapes. Automotive tapes are designed to seal better and release easier than hardware store tapes.
Old Mar 19, 2024 | 11:09 AM
1Butcher's Avatar
1Butcher
I'm not a painter, but I would agree, 1000 is too fine.
If it makes you feel better, I've been down this path before. It sucks. This is why I steer clear when it comes to body work.
Old Mar 21, 2024 | 08:24 AM
Tobey Anderson
4wd High
it was just blue masking tape
Old Mar 21, 2024 | 08:27 AM
Tobey Anderson
4wd High
dose it not bond with other primers?
Old Mar 21, 2024 | 09:23 AM
tjc transport
i ain't rite
it may, but i never had any luck with new primers and rustoleum paint.
regular blue masking tape is not good for body work, you need special tape for that.
i always used 3M green automotive refinish masking tape
Old Mar 21, 2024 | 01:00 PM
yeet's Avatar
yeet
Two things affected you here.
1000 grit is not enough "tooth" for the paint to grip tightly
You have to add Hardner to rustoleum if using it as a automotive top coat. If no hardener is added it can take weeks for it to reach a "tapeable" cure. This is due to EPA regs making it VOC compliant. The EPA ruined paints like rustoleum and old 55 years ago. Luckily, old 55 still sells the hardener separately.
Old Mar 21, 2024 | 02:41 PM
AuroraGirl's Avatar
AuroraGirl
I’ve wondered this about hardener. I’ve had good luck with krylon implement paint and gardener in outdoor stuff
Old Mar 21, 2024 | 05:27 PM
tjc transport
i ain't rite
rustolium mixed 60/40 with acetone will cure in about 20 minutes at 70 degrees.
