Need help with engine identification
Old Mar 18, 2024 | 02:09 PM
RoonieBJr's Avatar
RoonieBJr
8th Gear
Hey everyone! New here, I have spent the past 3 days trying to identify my engine. I just bought a 1979 f150 custom 4x4 4 speed manual. I have found so much misinformation and just back and forth stuff online, I really wanna be sure what I have here. As far as I understand, I think I have a 351m. The valve covers have 8 bolts, the cylinder heads are marked with “m” and the decal on the driver side valve cover shows engine family “5.8m/6.6 6GR” as far as I can make out. And for displacement is shows “5.8L 351cid” it also reads part number “D9TE-9C485-8TA” as far as I have found, that’s the designation for the head type but unsure of what that tells me. also I read somewhere that the thermostat being located on the block determines it is a 351m or a 400. Just trying to be sure what I have before I buy parts. Also not totally sure on parts compatibility from the 351m to the 400? My understanding is, crank and pistons are the only difference? And I think different heads and intake manifolds too? I’ll attach some pictures just in case I’m missing something here. Thanks for any help!
Shows the engine family+displacement markings
Shows the cylinder head part number
“M” casting on cylinder head
Thermostat location
Thermostat location
Old Mar 18, 2024 | 05:49 PM
85e150's Avatar
85e150
Welcome to FTE.
Most likely a 351M.
In any given year, the 400/351M are identical externally, and the crank and pistons are the only difference internally.
The carbs might differ, but both would be the Motorcraft 2150 type. (They come in different sizes)
What parts are you looking for?
Old Mar 18, 2024 | 08:43 PM
DaveMcLain's Avatar
DaveMcLain
I don't know of any reliable way to tell if one of these engines is a 351M or 400 from the outside especially one that has been worked on over the years. There might be some differences in the style of dampers originally used between the 351 and the 400 but the amount of balance weight is the same and they can be interchanged from one engine to the other. You could check the VIN and know what engine the truck originally came with but that could have been changed over time.
Old Mar 19, 2024 | 07:23 AM
manicmechanic007's Avatar
manicmechanic007
You have a 351M
The valve cover was the only way to tell the difference back then
Thank God, yours is still there
360-390 was the same way in the 70s You had to check the valve cover
You can double check yours with a drinking straw and pulling one of the plugs out.
Put the straw in the sparkplug hole and turn the 15/16 crankshaft damper bolt
The straw will move either up or down
Go until it hits the bottom and make a mark with a Sharpie magic marker or something
Then go until it tops out and make another mark
Those 400s had a 4 inch stroke
Your 351 has a 3.5 inch stroke
You will not be able to measure it perfectly, but you should not see anything over 3,5 inches of movement of the straw
Old Mar 19, 2024 | 09:42 AM
Crop Duster's Avatar
Crop Duster
Hopefully your vin sticker is still on the door frame. Use this site to decode it. Decoding '73-'79 Ford Truck VIN Tags - FORDification.net
Old Mar 23, 2024 | 08:09 PM
tbear853's Avatar
tbear853
The351M and the 400 as offered in these trucks have 8 valve cover hold down bolts in each valve cover. 5.8 is 351, 6.6 is 400.
88grandmarquis
35
Jun 10, 2024 09:02 AM
Mortec.se
Mar 16, 2023 01:28 PM
Martin Torres
1947 and Older Ford Trucks
Feb 21, 2018 09:05 AM
breezesboy
16
May 1, 2015 06:19 AM
GreenMonster76
Oct 15, 2013 07:46 PM
