2024 Cargo Lights not working
Old Mar 17, 2024 | 05:46 PM
camperfanatic01's Avatar
camperfanatic01
Anybody else experience this?
I did a few things in Forscan not related to cargo lights, and then noticed they didn’t work, so I changed it back thinking maybe I messed something up, still doesn’t work, so I checked fuses and disconnected battery for 15 mins, still doesn’t work.
Any body got any ideas to try?
Old Mar 17, 2024 | 06:47 PM
Fox-BLUE1's Avatar
Fox-BLUE1
It sounds like it’s not a fuse if they were working before the ForScan changes, but for some reason it is, check the 25 amp fuse for the Trailer Tow Module Battery Charge under the hood. Fuse 76. I sliced through my old travel trailer’s cord making a tight turn and it blew this fuse and my cargo lights stopped working. Replaced the fuse and they started working again.
Old Mar 18, 2024 | 09:04 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Did you enable “Lincoln Mode” in plain English by chance ?
If not restore your back up and see if they come back.
ZooDad
Old Mar 18, 2024 | 10:08 AM
camperfanatic01
I didn’t enable that. Unfortunately, I didn’t check the cargo lights to see if they worked before I started working in Forscan though, so I can’t for sure rule out a bad switch. I’ll keep messing around, and, if nothing else I’ll change the Forscan things back and try it, I’ve read the global open/close could cause it. I do have that enabled.
Old Mar 18, 2024 | 05:16 PM
camperfanatic01
Thanks for the suggestion, looked and all fuses are good, next thing I’ll try is reversing the few things I’ve tried with Forscan.
King Ranch 02.
1997 - 2003 F150
Jan 18, 2022 08:20 PM
Crowell
Sep 7, 2021 10:57 AM
bigmem124
Mar 26, 2010 09:08 PM
O1COBRA
Aftermarket Products
22
Aug 15, 2008 05:21 PM
