Need Help Engine Compartment Wires
Old Mar 17, 2024 | 11:23 AM
Deadbuck's Avatar
Deadbuck
1977 F-250 4x4 with Factory AC - Need help identifying these wires that go to nowhere in the engine compartment. See pics. Any help is appreciated. There are a bunch of empty wires behind the dash too. Not sure how to identify all of them. Thanks
Old Mar 17, 2024 | 05:10 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Elec diagrams start here. https://www.ford-trucks.com/forums/1...l#post14696846
Old Mar 18, 2024 | 12:56 PM
Deadbuck's Avatar
Deadbuck
Upon further review there are loose or disconnected wires and plugs everywhere. Is this normal as in a standard wiring harness for every option and then only certain ones are plugged it or connected? As an example the ash tray light and glove box light weren’t in place but the harness had the wires for them. Once I purchased them and connected to the harness they work.
so are all of these other empty wires for different options? If so is there a wiring diagram for the engine compartment harness? Thanks
Old Mar 18, 2024 | 01:25 PM
Drivewayfabricator's Avatar
Drivewayfabricator
I believe the red with blue stripe near the solenoid is the original start wire. Looks like someone has a new wire on a loop terminal in its place. Did they bypass a neutral safety switch maybe? Not sure why they would need to run a new wire up there.
Old Mar 18, 2024 | 01:53 PM
77&79F250's Avatar
77&79F250
Normal to have chaos behind the dash yes, factory maybe yes maybe no, I do not know for sure. I know that there is a difference in a 4 gauge or 2 gauge 2 warning light (on the instrument cluster) wiring harness. And a/c or not....I have not see a either or plug back there.
GGALLIN1776
May 2, 2023 09:53 AM
fpt2
Nov 7, 2022 05:38 AM
Dieseloholic1
Nov 23, 2020 03:45 PM
maltesecross
6.7L Power Stroke Diesel
Jan 13, 2013 09:34 PM
drizzie27
Mar 28, 2012 06:08 PM
