Trailer running lites not working
Old Mar 17, 2024 | 08:18 AM
rims421's Avatar
rims421
Trailering
I have a 2019 f250 with the factory installed towing package and brake controller.
The running light circuit is not powered up.
I have stop and turn signals working but no running lights.
I verified that I don't have power on either the 4 flat or the round plug
The lights work fine on the truck but not on the trailer
Checked all the fuses and they were all good.
Any ideas on what else I can check to get them working
Old Mar 17, 2024 | 08:22 AM
Poncho450's Avatar
Poncho450
See if the wiring harness unplugs behind the receptacle behind the bumper and check for corrosion.
Old Mar 17, 2024 | 09:38 AM
rims421's Avatar
rims421
Trailering
Old Mar 17, 2024 | 09:52 AM
scraprat's Avatar
scraprat
Top Answer: 5
Have you taken the trailer plug apart that goes to the trailer? Same for the truck plug take it apart and check the connection inside.
Old Mar 17, 2024 | 10:59 AM
HRTKD's Avatar
HRTKD
Which fuses did you check? From the 2017 Owner's Manual:
Check fuses #42 and #65. Those are listed as Trailer Tow Lighting Module.
#72 is turn signals and brake lights.
#84 is trailer backup lights.
#99 is trailer parking lamps.
Try it with another trailer to rule out that it's the truck. It probably is the truck since you said you didn't find power on the 7-pin or 4-pin.
Old Mar 17, 2024 | 11:08 AM
Poncho450's Avatar
Poncho450
One post will usually get the job done for you.
You can post in your original topic again if you feel it needs to be bumped up toward the top of the page.
Old Mar 17, 2024 | 01:06 PM
redford's Avatar
redford
FTE Leadership Emeritus
Duplicate threads merged into one thread.
Old Mar 17, 2024 | 08:07 PM
tfalk's Avatar
tfalk
I recently had the same issue with my 2018. When you say you "checked the fuses", what exactly did you do?
I used a continuity tester and it said I had continuity across the fuses. One of those cheap 7 pin testers from amazon showed everything OK.
When I used a volt meter, it said I only had 3 volts at the 7 pin for the running lights. I replaced the fuse with a new one and everything has worked since.
Old Mar 17, 2024 | 08:35 PM
Tideman's Avatar
Tideman
I’ve got the same problem. 2015 f350. what fuse number did you replace?
Old Mar 17, 2024 | 08:47 PM
tfalk's Avatar
tfalk
On my 2018, it was fuse #99 Trailer tow parking lamps. I've had to replace that fuse before, apparently it does NOT like it if you unplug the trailer 7 pin while the truck is running.
Old Mar 17, 2024 | 08:49 PM
Tideman's Avatar
Tideman
Thank you for the reply
Old Mar 18, 2024 | 05:08 AM
Wyldfire's Avatar
Wyldfire
Have you tried turning headlight switch to on not auto? Running lights not powered during daylight when on auto. Those of use with backup cameras on RV's have to set our switch to on to power back up camera that run off of running lights circuit.
Old Mar 18, 2024 | 05:52 AM
Tideman's Avatar
Tideman
Haven’t tried that. Easy to do. Thanks
Old Mar 19, 2024 | 05:36 PM
rims421's Avatar
rims421
Trailering
Thanks for the fuse box info
I replaced # 99 fuse and everything is good
Old Mar 19, 2024 | 07:13 PM
morehouse7's Avatar
morehouse7
FYI, for you to keep in the back of your head
Post 5
https://www.ford-trucks.com/forums/1...on-t-work.html
