DEF Tank Capacity
Old Mar 15, 2024 | 09:12 AM
SeaMunk's Avatar
SeaMunk
4wd High
DEF Tank Capacity
This is our first truck where we have had to deal with DEF fluid. We do know that the harder the engine is working the more DEF it consumes.
We are looking at pulling a heavy TT in mountainous areas where DEF may not be readily available. We have looked for the capacity of the DEF tank on a 2024 F350 XLT in all of the FORD literature that we have but we cannot find any mention the tank capacity.
We would like to know the capacity of the DEF tank and receive any recommendations on how much DEF we should carry for these out of town trips.
We would not be looking forward to the truck to going into limp mode when we are 100 miles away from the nearest supply of DEF.
Any assistance or advice will be greatly appreciated.
Old Mar 15, 2024 | 09:37 AM
HRTKD's Avatar
HRTKD
7.4 gallons according to my 2017 owner's manual. You can find this in the Capacities and Specifications section.
Unless I'm gone for a few weeks, I don't carry DEF. However, the 2024 uses more DEF than my 2017. Many truck stops have DEF at the pump.
Old Mar 15, 2024 | 09:39 AM
SeaMunk's Avatar
SeaMunk
4wd High
Thank you.
Old Mar 15, 2024 | 10:06 AM
4wd6.7L's Avatar
4wd6.7L
Old Mar 15, 2024 | 10:13 AM
SeaMunk's Avatar
SeaMunk
4wd High
Thank you.
Old Mar 15, 2024 | 10:40 AM
Strider250's Avatar
Strider250
You have a 7.5 gal tank. When I tow my 7K TT I get around 300 mpg for DEF.
Old Mar 15, 2024 | 11:00 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
When I fill up the DEF tank at the pump, I carry an old DEF jug and fill it up to carry with me.
On a typical work weekend, running 2200-2400 round trip, half towing, I will end up dumping the jug in at about 3/4 of the way through the trip.
Could usually make the trip without adding the jug, but then I would have to deal with the stupid low DEF warnings for 300 miles, driving me crazy, popping up before the gauge is even down to the halfway mark.
Also, if you fill at the pump, all the way to the top, you will get more than 7.5 gallons in.
Old Mar 16, 2024 | 11:50 AM
SeaMunk's Avatar
SeaMunk
4wd High
Thanks for all the comments. We found them helpful.
jtrux
17
Aug 7, 2023 11:00 AM
RigCity
May 30, 2021 11:05 AM
NStorm
Jan 5, 2020 08:00 PM
montey2005
6.7L Power Stroke Diesel
Dec 2, 2012 08:58 PM
