excursion brakes
Old Jan 23, 2002 | 10:47 AM
Monsta's Avatar
Monsta
Sit. Stay.
excursion brakes
[updated:LAST EDITED ON 23-Jan-02 AT 11:48 AM (EST)]>Monsta-
>Ball joints confuse me, what exactly are the ball joints on
>the 4x4?
They basically connect the wheels, bearings and brake components to the axle and allow the front wheels to be able to turn. Look behind your front wheel. You'll see the brakes and caliper, a bit back towards the axle you'll see a U-joint that drives the front wheel when in 4x4 mode. The connections above and below the u-joint are the ball joints
I would verify proper tire pressure (45/55), front end alignment and, of course, rotors warpness. A worn steering dampner could cause some vibration (mainly on turns encountering a bump) but wandering would also be a symptom. I would also verify proper torque on all your wheel lugs.
Old Jan 23, 2002 | 07:17 PM
john z's Avatar
john z
excursion brakes
Guys, testing for warped rotors is pretty easy. Take the tire off and place a pencil or something on a stand close to the rotor. Turn the rotor. You should be able to see if it is really warped. Needless to say, if you are experiencing vibrations when not applying the brakes, it is not a rotor problem.
Old Jan 26, 2002 | 07:27 AM
jdaniel's Avatar
jdaniel
excursion brakes
I got the x back, and it seems that turning the rotors cured the vibration. I also had the new style pads put on. Maybe the old pads were lying in contact with the rotors all the time, adn this led to heat buildup and vibrating slightly before the brakes were applied? Anyway, got to go back this morning, I had them change the tranny fluid, and now I have tranny fluid leaking. I think they reused the spring type clamps on the cooling hoses. I am going to take them some screw type clamps and have them use them.
Old Jan 26, 2002 | 09:16 AM
Monsta's Avatar
Monsta
Sit. Stay.
excursion brakes
Yeah, they redesigned the V-spring on the pads. Glad it's fixed!!
Funny, they shouldn't have had to remove a line with hose clamps on it. If they flushed it, then they should have unscrewed the lines running to the cooler.
Old Jan 26, 2002 | 09:04 PM
N700MS's Avatar
N700MS
excursion brakes
RBerry9511
Feb 11, 2017 02:07 PM
Fordperson
Mar 28, 2016 07:30 AM
HMS
Jan 24, 2016 01:05 PM
Mo111222
Jul 3, 2013 03:23 PM
98SurplusExpy
2004 - 2008 F150
15
Nov 12, 2006 01:54 PM
