04 f150 issues
Old Mar 13, 2024 | 12:22 AM
Cavebiotch's Avatar
Cavebiotch
2nd Gear
04 f150 issues
Need help. My 04 f150 just didn't want to move when in drive. Did code reader and ended up replacing sensor and throttle body but still nothing. Tried replacing the pcm but now it's stuck in anti-theft mode. Is there anyway to bypass it? Please help!
Old Mar 13, 2024 | 04:42 AM
techrep's Avatar
techrep
What DTC's did you have ? What motor ?
Old Mar 22, 2024 | 10:32 PM
Cavebiotch's Avatar
Cavebiotch
2nd Gear
4.6 liter. And the codes got were 2106 and 720. Which was the throttle body and sensor. Replaced those came back with no codes. Put the original pcm back in it for it to start again and now I have no gears.
Old Mar 23, 2024 | 07:33 AM
techrep's Avatar
techrep
have you checked the drivers side of the tranny ? plastic shift linkage holds the cable and breaks.
Old Mar 23, 2024 | 12:14 PM
getterdun1's Avatar
getterdun1
You may have already tried this but if not it might work: https://www.vehiclehistory.com/artic...i-theft-system
Old Mar 23, 2024 | 01:09 PM
BossHog39's Avatar
BossHog39
Check Main wiring harness from PCM down pside of engine between the firewall that run to transmission they are bad to come loose from there hanger and when it does the harness touch's the passenger side rear exhaust manifold and melts wires to the manifold or other wires in harness seen this on a couple of 04-08 F-150's and a 2006 Navigator already
shop.keeper
1997 - 2003 F150
Jan 20, 2010 08:04 PM
T Town
2004 - 2008 F150
Oct 19, 2004 08:09 AM
