6.2L V8 Discuss the 6.2L V8
2017 vs 2022 power difference
Old Mar 12, 2024 | 07:18 PM
xTIPPY A5x's Avatar
xTIPPY A5x
4wd High
My work truck is a 2017 f250 single cab with 75000 miles. My personal truck is a 2022 f250 extended cab with 12000 miles. The work truck I feel has loads more low end tourqe then my 22. Both are 3.73 gears. I know the tourqe numbers are the same on paper, do you think I'm just imagining it? Or maybe the weight of the cabs make a difference? I also noticed the exhaust on the work truck is clean as a whistle, while mine is all black and sooted up.
Old Mar 13, 2024 | 11:03 AM
Beechkid's Avatar
Beechkid
Single cab is about 500 lbs lighter
Old Mar 18, 2024 | 08:46 AM
River Wild's Avatar
River Wild
Different Tranny's too 6spd vs 10.
Old Mar 18, 2024 | 09:51 AM
kojimep's Avatar
kojimep
These are both F250's. I thought only the F350 with a 6.2 got the 10 speed after 2020?
Old Mar 18, 2024 | 09:55 AM
RainDesert's Avatar
RainDesert
Correct-
2017-2022,+ 6.2 f250 = 6r100 tranny
Old Mar 19, 2024 | 07:45 AM
Akley88's Avatar
Akley88
are the tires the same size as well?
Old Mar 19, 2024 | 03:14 PM
jcb804's Avatar
jcb804
How are both trucks configured? If the work truck is an XL single cab with nothing outfitted or being hauled then its considerably lighter and has the smallest diameter factory fitted tire. If your personal truck is anything above a base XL model it has larger diameter tires, more options adding weight, and considerably more weight already due to cab size.
Driverjoe92
Aug 28, 2021 09:14 PM
Randombro13
Feb 12, 2019 09:26 PM
tilopa
Sep 3, 2015 06:11 AM
Jocaren
General Diesel Discussion
13
Jun 8, 2008 08:40 PM
Fordenthusiasts
20
Jan 18, 2008 11:25 PM
