Bent pullout/tarp roll.
Old Mar 12, 2024 | 12:39 PM
wpg_250's Avatar
wpg_250
Anyone ever had this happen and were you able to bend it back good enough to still be usable?
Old Mar 12, 2024 | 11:13 PM
HRTKD's Avatar
HRTKD
That's a nasty problem. How did that happen?
I've never had to replace even the awning (fabric) on mine, so I don't know what your repair is going to involve. I suspect that by the time you dismount the spring loaded cylinder, you might as well install a new entire assembly.
Old Mar 12, 2024 | 11:47 PM
wpg_250's Avatar
wpg_250
Rain uncharauncharacteristically turned into mass amounts of snow one weekend.
Old Mar 13, 2024 | 05:02 AM
HRTKD's Avatar
HRTKD
Maybe you could find a used one at a local RV junkyard?
Old Mar 15, 2024 | 05:45 AM
Bugzilla46310's Avatar
Bugzilla46310
Pretty sure you are SOL on fixing that. Most likely replace with a new or used. Contact a dealer or manufacturer to see if you can just replace the bent part and use your arms.
Just curious on how many inches of wet snow caused that? Would insurance work with you on replacing it?
Old Mar 15, 2024 | 07:27 AM
wpg_250's Avatar
wpg_250
I made damn sure to pay for the best/most expensive insurance coverage so they damn well better cover it!
Forget inches lol, there was probably 3-4 feet of snow that accumulated in a 24 hour period. Where it's parked it only rains in the winter and MAYBE a few snow flakes hit the ground once a year, but the crazy a$$ el nino weather changed everything this year and the unit being 2500kms away I couldn't do anything about it unfortunately
Old Mar 16, 2024 | 12:29 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Wow yeah I agree with the others. There's no good way to straighten it, and it might crack if you did get it straight. You also might break other stuff if you were to try.
Old Mar 16, 2024 | 11:32 AM
5851a's Avatar
5851a
Mine did that during a monsoon rain, I had it tipped way down on one end but it didn't help. Insurance covered it after I paid deductible.
Old Mar 17, 2024 | 07:02 AM
SpencerPJ's Avatar
SpencerPJ
I have had mine apart, replacing the fabric. It is a hollow tube, and the ends have springs that insert a few feet. I would say yes, watch videos (might even consider a fabric replacement since it will all be apart) and give it a try. Personally, I think it would straighten fairly easy. Worse case, continue with insurance claim.
Old Mar 18, 2024 | 09:53 AM
CheeseheadFord's Avatar
CheeseheadFord
I don't see that being fixable either, but just something to think about, why leave your awning out when you're that far away, seems like only bad things could happen to it. Let us know if you're able to repair it.
Old Mar 27, 2024 | 03:32 PM
redford's Avatar
redford
FTE Leadership Emeritus
I know etrailer.com has replacement roller and fabric kits for most popular awning brands. I’m sure other stores would also have rollers.
ternus
35
May 20, 2024 05:42 AM
dads1977
S. California Chapter
Jan 15, 2017 06:16 PM
magicsac1366
17
Jun 17, 2013 08:07 PM
1974SuperCabF250
Montana Chapter
Oct 29, 2010 03:30 PM
ranger429
1978 - 1996 Big Bronco
Sep 29, 2008 02:15 PM
