Idiot light gauge cluster
Old Mar 11, 2024 | 09:36 PM
LiveFast_ChewSlow's Avatar
LiveFast_ChewSlow
1st Gear
I have a 76 F250 with idiot lights. I don’t currently have a working fuel gauge, idiot lights, or temp gauge. Basically just the speedometer works. It seems impossible to find replacements. Are there aftermarket options to fit the 14 pin gauge cluster that I’m not able to find or what are my options? Feeling pretty helpless. Thanks!
Old Mar 11, 2024 | 10:07 PM
Rubiranch's Avatar
Rubiranch
Sorry I can't help you.
I have the same instrument cluster as you and I hate it.
The oil pressure idiot light is disconnected and I replaced OP sending unit with a mechanical oil pressure gauge.
And I unplugged the brake pressure differential switch to shut the damn brake light off.
The alternator light still functions properly.
Old Mar 11, 2024 | 10:19 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
As I understand it, it is not easy to just swap to a 4 gauge instrument cluster, the wiring it different and so are the sending units. Option is to get a mechanical oil pressure gauge T'ed in and mount the gauge face it in a place easily watched. And you should be able to also use the OEM red warning light.
Rocketman gauge conversion of the ALT warning light to an actual amp gauge. https://www.rccinnovations.com/index...=menu-volt-all F100C7VO
Deadbuck
Feb 26, 2024 10:57 AM
f1butcher
Apr 25, 2022 03:29 PM
Mcrafty1
Apr 7, 2019 06:26 AM
BigMoby
Feb 9, 2019 12:21 PM
bkohne1
Minnesota Chapter
Jun 4, 2010 10:13 AM
