72 gauge lights not working
Old Apr 24, 2022 | 09:38 PM
f1butcher's Avatar
f1butcher
I already did a thread on my temp gauge not working, just brought a alt. temp gauge. I drove my truck for the first time at night and had no dash gauge lights , the switch if i turn it all the way - it will turn on the dome light, my head lights work. When online and most said it would be the head light switch, brought one from npd and it did not get the gauge lights working. So is it wiring , bulbs, gauge cluster, is there anyway to test the bulbs with gauge cluster removed, I have a 6 volt battery and a test light. Thanks for any info. f1butcher
Old Apr 25, 2022 | 10:07 AM
kenny nunez's Avatar
kenny nunez
Instrument lights
With the cluster removed pop out the bulbs and look at them. I replaced all of the bulbs with the “Cree” style. I also carefully removed the clear lens and cleaned the inside of the cluster. The “Cree” bulbs are not cheap but the results made the cluster as bright as new.
Old Apr 25, 2022 | 02:23 PM
f1butcher's Avatar
f1butcher
Where did you purchase the Cree bulbs ? Thanks for some info
Old Apr 25, 2022 | 03:29 PM
kenny nunez
Lightbulb Cree lighting
I got mine from Oracle in Metairie, La. You can also just google Cree 12 volt bulbs.
