Engine Rebuild Kits
Old Mar 11, 2024 | 02:19 PM
ericf5674's Avatar
ericf5674
Trailering
Engine Rebuild Kits
I have a 1949 Ford F1 truck with Flathead v8 239. I'm looking for a quality engine rebuild kit (no China junk if possible): valve springs + guides, engine gaskets, oil pump, piston set with pins +rings, main bearing set, camshaft bearing set, etc. Just need stock replacements or close to it.
Is this good or junk?
https://www.cleggengine.com/engine-r...1949-1953.html
If you all were going to pull the engine what would you change? Assuming water pumps + listed above. I have (2) engines both seized up don't know the history. I was hoping to get them magaflux tested and resurfaced and possibly hone the cylinders if needed.
Old Mar 11, 2024 | 05:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Those components look good to me, almost exactly what I spec'd when I had my engine rebuilt. Not familiar with those cam bearings, tho. Maybe Clevite isn't making them anymore?
Honestly I'd be amazed if you can get by with a hone job. That rebuild set includes new pistons, if you aren't going to bore it I'm not sure I'd replace the pistons. Why did the engines seize, are they rusty in the bores?
Old Mar 11, 2024 | 05:49 PM
ericf5674's Avatar
ericf5674
Trailering
I don’t have the engine history but the engine appears seized. If the cylinders are too bad, you would just reuse the stock piston? Would you replace the piston rings?
Old Mar 11, 2024 | 06:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If the cylinders look bad, I'd have it bored oversize and replace the pistons to match. New rings and pistons in a lousy bore won't last long. Do you have the engines apart yet?
Old Mar 11, 2024 | 06:39 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
We are getting into questions that really can't be answered until the blocks are disassembled and evaluated to understand condition, any previous bore operations and whatnot. If going this far with a rebuild, I would highly considering putting in new pistons and rings anyways as in the grand scope, they don't cost that much.
Old Mar 11, 2024 | 08:53 PM
38 coupe's Avatar
38 coupe
Disassemble the engine(s) before purchasing anything. Make sure you have a rebuildable block. Flathead V8s are know for freeze cracks in the oil pan rail and heat cracks in the cylinder head deck. There are a lot of flathead V8 motors still out there, you may need to dig into a few to find a good block. Once you have a good block, then purchase the pistons and other parts that fit the rebuild that engine needs.
Old Mar 12, 2024 | 05:47 PM
KirkF's Avatar
KirkF
Completely disassemble the engine
Take it to machine shop with the crank
Have machine shop check for cracks (magnaflux)
If the block has acceptable cracks (They all have some, but not all cracks are created equal) then have them tell you the next piston oversize you can bore to, and what they can turn the crank to.
Many people go to the common overbore of .125 over on these blocks and move to a modern piston.
However before you know that block is useable don't bother spending any other money.
Kirk
Old Mar 12, 2024 | 05:59 PM
bmoran4's Avatar
bmoran4
There is no way I would go .125 over on a first bore... I would keep it as small as possible, the first jump usually is .030.
Old Mar 12, 2024 | 06:45 PM
KirkF's Avatar
KirkF
I would guess that over 80% of rebuilds go to the standard .125 oversize these days. Its the most common size for a modern piston.
Kirk
Old Mar 12, 2024 | 07:02 PM
bmoran4's Avatar
bmoran4
It depends upon what one is going for. For longevity and less risks, you go with the smallest bore you can and that is what most any experienced traditional Flathead machinist do. Any cost difference is more than made up for when you account for .125 approaching the limit of the block bore and thus needing to obtain a new block at the next rebuild. Now, those chasing excessive performance will go straight to the largest bore, so for the folks you may hang around, your 80% guestimate may be true, but not necessarily universally advisable.
.125 is no more a standard oversized piston than say .030 and .060.
Old Mar 12, 2024 | 07:28 PM
mtflat's Avatar
mtflat
While many flatheads can be bored to +.125" you should always have it sonic tested before you go that far. If there happens to be a thin spot in the casting you'll be into the water jacket.
An old flathead friend wanted to keep at least .090" of wall thickness to avoid hot spots and wall waving.
Old Mar 12, 2024 | 07:57 PM
charlie g's Avatar
charlie g
FTE Community Team
i always have our local machine shop tell us what it needs to be bore to, always have them check for cracks esp in the center exhaust ports we never go past 080. unless building a big inch stroker.
parts wise that's a good price all good parts, durabond happens to be a good product
Old Mar 13, 2024 | 06:12 AM
seaves46's Avatar
seaves46
Look for a seller on ebay called falconglobal , he seems to do engine rebuild kits at a reasonable price .
Old Mar 13, 2024 | 11:43 AM
KirkF's Avatar
KirkF
At 0.125 over you are still good to bore twice more. When you move to a modern piston and low tension rings, you are never going to wear a cylinder again. They are the reason we don't do this anymore with modern cars.
Flatheads are amongst the most expensive motors to build at this time, so be sure to make the best decisions for your personal situation.
Kirk
Old Mar 13, 2024 | 12:36 PM
bmoran4's Avatar
bmoran4
Kirk, it seems you are advocating for moly piston rings and the matching pistons. Those technologies and the advantages they tout do not really matter much for our pickup trucks, only for those who excessively and compulsively chase performance and building out their engines as such. As many have stated, .125 is just about it as far as one can optimistically hope to take an average flathead block. And as to why we don't rebuild modern engines these days, well, it comes down to time and cost. By the time the engine is worn, the vehicle isn't worth the rebuild and the abundance of running junkyard donor engines is plentiful and more cost effective. Even when modern engines have issues with the pistons and rings (such as Subaru), the warranty fix isn't to rebuild the engine, but to swap it for a new short block because of time and costs. In our hobby, the costs doesn't always have to make sense, but not all of us need racing performance builds.
