What is this?
Old Mar 10, 2024 | 03:08 PM
EXTREME_SD's Avatar
EXTREME_SD
What is this?
It's on the negative side of the passenger battery, between the post and the actual wire.
Im hooking up the ground wire for my Amp and just wandering if it matters if I put my ground wire on either side of that?
Old Mar 10, 2024 | 03:16 PM
honda250xtitan's Avatar
honda250xtitan
gas truck? looks like the wire you would unplug if you wanna disable the autostop/start.
but yea you can undo that 8mm and throw a ring terminal on it and put the nut back on.
Old Mar 10, 2024 | 03:22 PM
rydaddy's Avatar
rydaddy
I believe it is a sensor to measure current draw on the battery.
Old Mar 10, 2024 | 03:36 PM
EXTREME_SD's Avatar
EXTREME_SD
After more research it looks like it's a BMS Battery Monitoring System, still researching it.
So I wonder if I would ground Amp before or after that device?
Old Mar 10, 2024 | 04:03 PM
rydaddy's Avatar
rydaddy
I would put it right on top so that it would measure that load as well, or just ground the amp to the chassis.
Old Mar 10, 2024 | 04:23 PM
EXTREME_SD's Avatar
EXTREME_SD
Found a pretty good video on a f150 forum. Looks like I'll put it after the sensor just like you suggested.
Old Mar 10, 2024 | 08:32 PM
2004Limited's Avatar
2004Limited
LOL, forty years ago, before the internet had videos, we probably would just ground it to the frame!
jerkypants
May 28, 2014 07:20 PM
GLaJudice
May 7, 2014 02:10 PM
eff15thtee
2004 - 2008 F150
May 6, 2011 04:39 PM
Prozon
16
Jan 12, 2010 11:16 PM
chris_n_va
Dec 19, 2002 03:50 AM
