Source for That LOOOOONG Serpentine Belt
Old Mar 10, 2024 | 01:43 PM
extrachrispy's Avatar
extrachrispy
I have a 2020 F450 with dual alternators. O'Reilly's doesn't carry that LOOOOOOONG serpentine belt, and I really like to have a spare with me, just in case (or even just on-hand in case I start to see cracks in the ribs of the one that I'm running).
Old Mar 10, 2024 | 01:51 PM
senix's Avatar
senix
try napa if not in stock can order.
Old Mar 10, 2024 | 04:35 PM
Just Chilling's Avatar
Just Chilling
Do you typically have trouble with those belts?
my 17 powerstroke is still running on the original one with 275k
on it. I mentioned to the mechanic to check it and he said it looks good.
Old Mar 10, 2024 | 05:43 PM
4wd6.7L's Avatar
4wd6.7L
You can order one from a bunch of different places. I have thought to do the same, have one as a spare. At around 9k miles my AC compressor seized up, it smoked my belt a couple times till I realized what was happening. After the compressor repair was completed, I noticed that a new belt wasn't listed on the work order.
Old Mar 11, 2024 | 01:50 PM
Disarray's Avatar
Disarray
I would definitely replace that. These newer belts are made out of different materials that don't typically crack like the older belts. They just wear down until the snap or come apart. A savvy mechanic can look at the side profile of the belt and see that it has gotten much thinner. These belts typically sit below the surface of ribbed pulleys and makes them a dead give away to being beyond their service life.
Old Mar 14, 2024 | 02:05 AM
Euroman's Avatar
Euroman
That just happened to me, truck is still waiting the compressor and other bits to arrive, then it’s a full flush and rebuild. I always carry a spare, but in this case it wouldn’t have helped as the clutch was solid as well.
kemerick
Aug 30, 2007 08:56 AM
pat2724
1997 - 2003 F150
Apr 17, 2007 07:57 PM
Marc150
Apr 12, 2004 05:41 PM
