Starting problems
Old Mar 10, 2024 | 04:23 AM
Aus f150's Avatar
Aus f150
Trailering
Starting problems
my 90 f150 wont start in neutral ,only in park. Fitted new actuator and ignition switch and new NSS.
5.0 Engine and AOD trans.
Any guides would help as i just got this truck and i am learning all the time.
Old Mar 10, 2024 | 07:28 AM
manicmechanic007's Avatar
manicmechanic007
Your reverse lamp / neutral safety switch on the trans is not adjusted correctly?
What happens if you hold it in start and shift the trans through the gears?
Does it start in 2 positions then? Verifying it is out of adjustment?
Old Mar 10, 2024 | 12:27 PM
Aus f150's Avatar
Aus f150
Trailering
Installed new switch and the trans is a AOD. When i move the shift lever on the column it only starts in Park, nothing in neutral. Reverse lights work.
Old Mar 10, 2024 | 01:58 PM
Prototypemech's Avatar
Prototypemech
Start=crank?
Bad NSS. Common for new switches to be bad out of the box. Do you have the old one you can swap in?
Old Mar 11, 2024 | 06:48 AM
manicmechanic007
I agree, bad switch
If it will only crank in one position, your new switch is no good most likely
Keppe87
21
Dec 1, 2021 06:36 PM
Fakeraptor
2004 - 2008 F150
30
Oct 18, 2021 12:12 AM
tjdad62
17
Feb 12, 2015 01:49 PM
cody41
1983 - 2012 Ranger & B-Series
Nov 29, 2003 07:43 PM
