Frame Radiator support Holes
Old Mar 9, 2024 | 03:45 PM
RVF250Michigan's Avatar
RVF250Michigan
4wd High
Hello all !
During a intense round of seeing how many beers i can drink and still Mig weld. I forgot to document the measurements of my front end. Do any of you FORD experts know exactly where the radiator mount holes are on the the frame ? I welded a new plate on both my front end.
1979 F250 4x4 custom cab.
Old Mar 9, 2024 | 08:59 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Maybe you can figure it out from here? Excerpts from a body builders layout book. Can be found here maybe? https://www.fordification.net/tech/bodybuilder78.htm I seem to remember a fellow FTE members making a layed out measurement diagram/pic of that area. I am looking to the pic.
Want the book? https://www.ebay.com/itm/33525821960...AaAgwuEALw_wcB
Old Mar 10, 2024 | 09:41 AM
tbear853's Avatar
tbear853
Originally Posted by RVF250Michigan
Hello all !
If you mean right to left, they'll be same as holes on core support ... 32.04" center to center ... or 16.02" from the frame center line. 32.04" is less than 32-3/64" which is just a hare's breath over 32".
If you mean forwards to back .... you might need to mount core support to inner fender aprons to mark ... but. I'll aim to grab a meaningful measure today from frame bumper surface end <> back to hole centers.
Old Mar 10, 2024 | 11:20 AM
RVF250Michigan
4wd High
Thanks for all the info ! Really helps..
The front to back measurement is what is stumping me.
Old Mar 10, 2024 | 11:33 AM
tbear853's Avatar
tbear853
OK, my '77 is a 4x4 F-150, but I once compared it side by side to a '77 F-250 4x4, frame was the same except for a few suspension points due to differences in my coils and his leaf springs, etc. Frame rails were exact same, even most unused holes were the same. 4x4s have different front cross members than 2x4s.
From the very tip of the round end of the frame where the front bumper mounts on mine is 9-3/4" back to the hole centers. To the cross member face over the front axle to those holes is 5-3/4" on my truck. Was 15-1/2" from the tip of the frame rail behind the bumper to the cross member. See where that fits.
Maybe it helps?
Old Mar 10, 2024 | 12:05 PM
RVF250Michigan
4wd High
Exactly what i was looking for !
You all rock !
Old Mar 10, 2024 | 12:58 PM
HertzHound's Avatar
HertzHound
A little late, but if you want to compare. I have my 77-1/2 F250 down to the frame now. The reference hole is the rear bolt on the front shackle. The line was squared up from underneath where there is no curve like above.
Old Mar 14, 2025 | 10:17 AM
RVF250Michigan
4wd High
Thanks again for all the help !
12F350
Dec 14, 2023 12:08 AM
Tul01
Apr 24, 2022 09:28 AM
vidaliaman
Jul 7, 2017 12:18 PM
joegeds
Jun 10, 2016 03:26 PM
jnb53f100
May 8, 2014 10:19 PM
