2011 F-150 3.5 code help
Old Mar 6, 2024 | 04:19 PM
Whitemolasses's Avatar
Whitemolasses
7th Gear
Hello, I have a 2011 F-150 3.5 with 150k miles on it. I've changed the oil regularly since I've owned it in June every 3000 miles. At startup this afternoon it feels like it stutters bad. Especially lower rpms and idles rough. I checked the codes and I had a slew of them pop up. P0017, 18, 19, p0365, 0369, 0390, and 0394. How bad is my problem with all of them coming up at once and what can I do to try and fix them. I have checked the electrical connectors and I have 2 new vvts for the passenger side as p0017 was the first code it ever threw. But all the rest at once can't be good. Any help is greatly appreciated.
Old Mar 6, 2024 | 06:18 PM
RLXXI's Avatar
RLXXI
Unfortunately all of those codes lead to one repair procedure. Timing group replacement, gears, chains, tensioners, guides, possible oil pump, etc.....
Old Mar 7, 2024 | 05:31 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
That's a tough place to be on an older truck. If that happened to my 2011 truck even in it's pristine condition, I'd have to weigh whether or not the truck is worth that kind of a repair and if I can find the value in the bloated prices of a new(er) truck.
Old Mar 7, 2024 | 05:51 PM
Whitemolasses
7th Gear
That's what my fear was once I first got the p0017. But it ran completely normal until just the other day when it threw all the rest. So I had just assumed it was a bad sensor.
Pf2928
Dec 21, 2020 07:27 AM
jellis50
2009 - 2014 F150
May 1, 2017 03:14 PM
trdsmn
Dec 10, 2013 08:19 PM
haldavis
1997 - 2003 F150
Mar 23, 2011 09:46 PM
sparkey101
1997 - 2003 F150
Oct 7, 2007 03:25 PM
