Sponsored by: Auxito
Valve knock
Old Mar 6, 2024 | 08:36 AM
Dead_throughout's Avatar
Dead_throughout
4th Gear
Valve knock
I have a small valve knock on the passenger side of the engine and i was wondering if yall would know how to fix it. the truck runs great otherwise and hasnt thrown any error codes. But i wanna set valve clearance on the engine anyway. Do yall have the specs? I already have all the torque specs in the world i could need, i just need valve clearance specs and if yall have any other suggestions let me know.
Old Mar 6, 2024 | 01:54 PM
fordiesel69's Avatar
fordiesel69
All the engine offerings use some form of hydralic lash adjusters. They are fed by oil pressure and take care of the rest.
Did you transplant a detroit diesel 4-71 under the hood or a 4BT?
Old Mar 7, 2024 | 04:37 AM
manicmechanic007's Avatar
manicmechanic007
You have what are called positive stop rockers or otherwise non-adjustable valves
If a 5.4 , you have HLAs under the rockers
Either type is not adjustable with a conventional feeler gauge
The HLA takes up the slack
If a conventional pushrod motor, you might have a flat cam lobe or a sticking or plugged up lifter
Saying what you are driving is a good first step
DLConst
Oct 3, 2021 07:34 PM
snorindad
Dec 31, 2020 09:03 AM
BonebrakeJones
Jan 2, 2006 12:10 AM
