Glow plug? Or something else?
Old Mar 4, 2024 | 08:33 PM
Emittim3's Avatar
Emittim3
Randomly and seldomly getting a check engine light with this Forscan log info:
===PCM DTC P0672-E0===
Code: P0672 - Cylinder No. 2 - Glow Plug Circuit
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Powertrain Control Module
Diagnostic Trouble Code details
This DTC may be caused by :
Open circuit.
Short circuit
Possible causes are:
Glowplug control circuit
Glow plug cylinder 2
GPCM
===END PCM===
===OBDII DTC P0672-C===
Status:
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
Open circuit.
Short circuit
GPCM
What's the typical reason for this code being thrown? Should I just replace the plug and see if that stabilizes things?
Old Mar 5, 2024 | 05:27 PM
450kexcursion's Avatar
450kexcursion
I am going with check the harness going into the valve cover. I dont think I have ever seen a glow plug not working throw a code. I had a few go bad a few years ago and never tossed a code. But the wire harness is a big issue if it is a 7.3
Old Mar 5, 2024 | 08:35 PM
Emittim3's Avatar
Emittim3
It's the ole "super reliable" 6.0.... still harness?
Old Mar 6, 2024 | 10:10 AM
oharal's Avatar
oharal
Idk anything about 6.0's other than the obvious "oh no" factors... but on 7.3 I have seen the glow plug connectors pop off on the plug itself. But the easier thing to check and more lkely problem is damage to the harness where it connects to the valve cover gasket. Some of that may be applicable to the 6.oh no
Old Mar 11, 2024 | 10:32 AM
bwguardian's Avatar
bwguardian
The 7.3L Excursion has a GPCM which will throw a code for individual glow plug issues. I would first pull the green and black plugs and check for burnt pins. Then I would ohm the outer 2 pins on each side at the valve cover plugs and also look for bare wires from rotting insulation on the pig tails. This can be done before you pull the valve cover, but once you do I'd unplug the UVCH and look at the valve cover gasket for burnt pins before I pulled the glow plug. If you do decide and/or need to pull and replace the #2 glow plug I'd go ahead and replace all of them, or at least the ones on that bank because once one has failed the rest will likely follow suite shortly thereafter...
Old Mar 12, 2024 | 03:19 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
On a 6.0 that usually means replace the glow plug.
Sometimes it's the GPCM but more often than not it's the glow plug itself.
dondolittle2
6.4L Power Stroke Diesel
Mar 21, 2016 07:55 PM
Jjk27
May 10, 2015 01:54 PM
jereli
Jan 31, 2014 10:34 PM
foul1
Aug 16, 2010 05:57 AM
Wings
Mar 13, 2006 11:01 AM
