Had this once before so I knew exactly what it was. A pop click kind of sound at slow speed hard turns. Last time it was the bolt/nut that goes thru the track bar mount for the track bar. I used two 30mm wrenches and a small bar to pry it tight today. Turned it about one flat . Pop-click noise is gone.
so I guess I’m going to have to spring for a 400 ft lb torque wrench. Up until this point I have been using various impacts that have specific ranges….guess I will need to final torque with the wiz bang 400 dollar impact .
