HD headlight harness issues
Old Mar 4, 2024 | 04:47 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Originally Posted by Anonymous12
Did you hook up both fusible links? Are they good?
Did you hook up both grounds? Are they good?
Old Mar 4, 2024 | 04:56 PM
McLeod's Avatar
McLeod
From what I can tell his truck does use 9004 bulbs but the harness is for 9007 bulbs
Maybe you can repin the sockets
Edit: I see Edgethis beat me to it while I went into edit the first time.
Old Mar 4, 2024 | 05:00 PM
Edgethis's Avatar
Edgethis
Originally Posted by McLeod
From what I can tell his truck does use 9004 bulbs but the harness is 9007 bulbs
If this is the caee, All is not lost! You could rewire the harness ends to match what your truck and bulbs require. A bit more work but doesn't cost anything except time and some elbow grease.
Old Mar 4, 2024 | 05:10 PM
McLeod's Avatar
McLeod
The only problem I can see is if he sells the truck to a new owner who has no idea.
If OP has been sending power to ground there may be some blown fuses at this point so check thoroughly
Old Mar 4, 2024 | 06:21 PM
Anonymous12's Avatar
Anonymous12
I will look into the power/ground. I’m thinking that the low and high beam are switched in the harness looking at the diagram. Don’t plan on ever selling it, but if I do they are already screwed, the viper alarm creates a rats nest under the dash.
It is for a 9007, I will check fuses. Thanks for the help!
Old Mar 4, 2024 | 09:53 PM
AuroraGirl's Avatar
AuroraGirl
my bad i forgot you had a 88 not a 92-97, yes you have a 9004 bulb setup so your bulbs are right. so you will have to modify the bulb sockets and replace the bulbs or you must modify the harness and keep your bulbs. thats the cheaper route. may be easier depending on how this harness looks
Old Mar 4, 2024 | 10:09 PM
Anonymous12
I contacted bronco graveyard to see if they would send me the correct harness. If they won’t then I’ll modify the one they sent me.
buttwheat
Aug 30, 2012 10:15 PM
1966Tbird
19
May 18, 2009 05:20 PM
Paultex
Mar 7, 2007 09:58 PM
