No Compression Cylinder 5
Thank you again for your continued support, advice, and patience in educating me and helping through this.
Grady
So you've verified that cylinder 5 leaks down into the intake (what you suspect), then you tried in a cylinder that was good, and it pushed the piston down. What I'd do next, is put constant air on cyl 5 and bar (turn the engine) an entire rotation and see if the sound that you hear in the intake ever stops. It's also possible that you're hearing the air go through the cylinder and back into the intake via the PCV valve....for the sake of this testing, you should remove the pcv valve. While compressing cyl 5, and turning the engine by hand, you'll be listening for any change in the intake. You may find that the intake noise stops by removing the pcv valve.....in which case, easier to run the test described.
Isn't the PCV valve in the valve cover, which I have removed? If not, then where is the PCV you are referring to that needs removed? Either way, I will do the test you mention, keeping constant air going in and rotating the engine by hand to listen for it to ever stop escaping from the intake (though I expect less when the exhaust valve is open).
I believe the pcv valve is on the drivers side valve cover, and you're working on #5, the passenger side? If so, the hose in your pass side valve cover is the fresh air entry for the pcv system, and you'll have to remove the pcv valve from the drivers side in order to eliminate the path of compressed air from cylinder to intake
Thanks again, I am sort of looking forward to what lies ahead, sort of...
Grady
Rule #1 with ac components: only remove them when necessary. So often, you can swing the pump and lines outta the way to perform the work you're after. Only remove something from the system if it dead ends the work.
Watch some of the vids, pay close attention to tooling that needs to be collected, and go from there.
This would also be a spectacular time to add some long tubes!
Ford 6.8 liter V10 Gas Engine
Cylinder Head Bolt torques
NOTE: The cylinder head bolts must be discarded and new bolts must be installed. They are a tighten-to-yield design and cannot be reused.
Step 1 = 40 Nm, 30 lb.ft
Step 2 = + 90 degrees
Step 3 = + 90 degrees
Are long tubes beneficial from a performance/fuel economy perspective that will recoup the additional costs, or are they more of a cool thing that also makes cool noise? I'm not familiar with exhaust upgrades, or performance upgrades in general. Just wondering if I would be better off saving that money for fuel for road trips, on a tuner (I've generally be opposed to tuning as I associate it with wanted to hot rod the vehicle, which my goal is durability and reliability, but I think my assumptions are poor), or toward other needs (suspension needs upgraded, brakes, etc...). Also, is there a way to clean injectors and is it worth doing/sending somewhere? I don't know the state of mine, other than some are missing the pintle pieces and such. I just know I was chasing misfires on a few cylinders and have new plugs and COPs. I moved injectors around and a couple of the misfires didn't come back right away, but now I am on this project. Just curious if injectors are a known culprit or if they are usually pretty solid and not worth wasting money on until something is confirmed.
Thanks again. Gathering information before I get started will be helpful, and I have time as I don't anticipate being able to do anything for a month or so, unless some things happen in a hurry...
Please share thoughts on what I should replace or not while I am in this far. So far I am thinking the following:
Timing components (chain, guides, etc,) I assume there is a kit for this
Gaskets (head to block, valve cover, timing cover, exhaust manifold, intake manifold)
Water pump
Power steering pump
idler tensioner pully (it looks pretty new, but thinking I should just replace anyways, though I have not looked up cost haha)
head bolts
crank shaft bolt (stretch bolt also, correct?)
My intake manifold has at least one of the spots for the COP to screw into that is busted, not a big deal, but is it worth looking for a replacement intake? Or if keeping, is there anything I should do to it? I feel I've read about having it cleaned, may be something the shop that rebuilds the heads might be able to do?
I'd like to consider injectors. Are refurbished injectors a good idea? I've seen some shops on Ebay that say they refurbish OEM injectors, and have seen them for around $220-250 for a set of 10 of the orange Bosch ones. Thoughts/recommendations? I have injectors missing the pintle cap, O-rings, etc., so at the minimum I will need buy those replacement parts.
All my clips for attaching to the injectors are broke. One side were zip tied to the injector, other side was just held in place, but no clip. I busted one clip house during removing everything, got smashed. Are these easily replaced without re-wiring?
I assume having my heads taken to a shop and rebuilt is the best option. The other option would be to purchase refurbished heads. Thoughts? When taking to the shop, what should I make sure is being done? I plan to see if they can also timesert all the spark plug holes while they have them.
Long tubes were mentioned previously, is this a worthwhile consideration? If so, what are some recommended options? I know some have gone away that were recommended a few years ago.
Thank you again everyone for helping me to this point.
