Front brakes question
Old Mar 2, 2024 | 02:36 PM
77ford250's Avatar
77ford250
Hello I have a 1977 F250 custom 2wd and I’m installing my new rubber brake lines for the front calipers and I’m have a issues on alignment it’s been about two years since I disassembled the front suspension and rookie me I didn’t take good enough pictures and I don’t have the old lines anymore from moving but when the cube on the brake line is flush on the caliper it’s not aligned with the bolt and when I align it it’s not setting
Old Mar 2, 2024 | 04:20 PM
aldridgec's Avatar
aldridgec
Not setting...what? Tight atagisnt the caliper? Doesn't need to.
Old Mar 2, 2024 | 04:47 PM
redroad's Avatar
redroad
Make sure you don't have the right and left switched and you have all the mounting hardware to include the copper washers.
Old Mar 2, 2024 | 05:00 PM
77ford250's Avatar
77ford250
this is what is going on there’s a gap behind the block I must have it backwards or wrong line and I’ve verified it’s the right side
Old Mar 2, 2024 | 05:52 PM
tbear853's Avatar
tbear853
Flip them over and use a sealing washer between the block and the caliper.
Old Mar 3, 2024 | 01:16 PM
77ford250's Avatar
77ford250
Thank you for the help I finally noticed to flip it over after I posted the second set of pictures i don’t know they put that little lip at the bottom then?
Old Mar 3, 2024 | 01:28 PM
beardedcap's Avatar
beardedcap
if you notice on one side of the bracket there are like serrations cut into it that bite into the copper washer and deform it so it seals
77ford250
Oct 28, 2023 12:14 AM
stubby066
May 21, 2022 01:11 PM
1955Qfc
Jun 16, 2020 11:05 AM
mcbrine
Jan 4, 2019 08:25 PM
Rovernut
26
Apr 1, 2013 03:30 PM
