Dome Light Install
Old Mar 3, 2024 | 10:53 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Like Kevin said, the wires plug in on the light side of the switch. The offset in the switch-hole gives the room the wires need.
The hoops on the back of the switch are not the contacts. They slip inside the hoops. The little hooks in the end of the contacts (A) hold the bullet connectors in.
I'm guessing where you opened the hoops and forced the bullet connectors in is putting too much pressure on the contacts, pressing them into the switch and preventing the slide from moving.
Old Mar 4, 2024 | 06:12 AM
Harrier's Avatar
Harrier
I will compare it closer to the original switch I have. It didn't have continuity between the contracts but maybe it will just need some cleaning.
The original switch still had wires attached and the Ford bullet connectors actually had a connector coming in from each side.
Old Mar 4, 2024 | 10:44 AM
Old F1's Avatar
Old F1
Color me confused ?
Not really familiar with 6 volt circuits as I converted my '51 to 12 volt.
Your wiring diagram looks like it switches the current on the hot (battery) side of the circuit (a two wire system).
Most dome light circuits switch on the ground side, the bulb is hot all the time but the circuit is not completed until the lamp is grounded.
A one wire system, I think this was so that the door jam switch was only one wire to ground. This would explain the lack of continuity (maybe).
Old Mar 4, 2024 | 10:58 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
In the shared wiring diagram, the light is always grounded to the frame via the fixture. Then either door switch (dual terminal) can complete the circuit through to the battery, or the dome light switch itself can complete the circuit to the battery allowing all illumination triggers.
Old Mar 4, 2024 | 06:52 PM
EffieTrucker
As bmoran40 said, at some point (1952 maybe?) They changed the interior lights and the start circuit to be always grounded and switched hot.
Then somewhere in the 1960s they changed the interior lights back to switched ground.
Old Mar 5, 2024 | 06:04 AM
Harrier's Avatar
Harrier
I compared the two switches, the modern one is slightly bigger. I bought this one at LMC truck.
Working the switch got it moving again. EffieTrucker was correct, my widening pressed one of the contacts in which caused the problem.
I managed to blow a fuse on my first attempt with it wired together. My switch must have contacted the cab.
Notice the original bullet connectors going out each side. Not sure how they managed that, but they are considerably shorter than mine.
Old Mar 5, 2024 | 07:28 AM
bigwin56f100's Avatar
bigwin56f100
I'm going to guess and say that when I removed that light might have unplugged the wires and reconnected it wrong
Old Mar 5, 2024 | 01:05 PM
Harrier's Avatar
Harrier
Well that makes sense. You would have to have removed the connectors to get the switch out.
F2502011
2023+ Super Duty
32
Sep 4, 2025 07:31 AM
excursion_7.3
Oct 1, 2023 07:07 PM
A/Ox4
Mar 16, 2012 12:55 PM
lamenytro
Feb 10, 2011 07:13 PM
___
Aerostar
May 5, 2006 07:41 PM
