Expedition Cruse Control Failure
Old Mar 1, 2024 | 08:28 PM
pisacksen's Avatar
pisacksen
4th Gear
Cruse control just stopped working after master cylinder and booster replaced. Did paddle self-test failed on right side paddles. Replaced both paddles from Amazon, still fails. Could it be the brake cruse control switch? If it does not have continuity or has failed would this cause the non-engagement of cruse? Verified fuses too, all valid.
2003 Expedition XLT 5.3
Old Mar 2, 2024 | 01:32 PM
lv2race's Avatar
lv2race
I had to replace the cruise control deactivation switch on both 2000 and 2003 Expo's to get the cruise control to work. They were a recall item from Ford so the 2000 was replaced at the dealer. I replaced the '03 myself.
Motorcraft part number SW6350
https://www.rockauto.com/en/moreinfo...F%2BOMrn1r4aOG
Old Mar 2, 2024 | 01:37 PM
pisacksen's Avatar
pisacksen
4th Gear
This is the switch on my model of expedition.
https://a.co/d/6UcoTDe
Old Mar 2, 2024 | 02:02 PM
lv2race's Avatar
lv2race
The part (repair) I posted is connected to the brake booster.
Old Mar 2, 2024 | 02:28 PM
pisacksen's Avatar
pisacksen
4th Gear
The cutoff switch on my model 2003 is by the brake peddle
Old Mar 2, 2024 | 03:15 PM
lv2race's Avatar
lv2race
From my 2 different Expo's with the same problem, I thought they all had the harness.
Old Mar 2, 2024 | 06:55 PM
pisacksen's Avatar
pisacksen
4th Gear
Mine has the brake peddle cutoff. Suspected the cylinder one; however, mine does not have.
Old Mar 4, 2024 | 10:19 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Master one is part of some NTHSA recall still open for these trucks.
Cruise works on mine, so I am of no help. It is dead on the '01 Screw, so hopefully you receive some resolution and I have places to eyeball.
sampelje
Apr 26, 2015 09:22 AM
hawesra
Jul 21, 2014 08:01 PM
gmcc
Nov 29, 2003 07:04 PM
TCarroll
Sep 13, 2002 05:00 PM
turbo497
Jan 14, 2001 02:09 PM
