Front spring replacement chart
ok i think i got this narrowed down. common upgraded front springs are
CODE:
V - Part# F81A-5310-ADB
X - Part# F81A-5310-AFA
then the upgrades for the rear are:
CODE:
B - 3C34-5560-L (6840lbs, F350 SRW, and some F250's)
C - 3C34-5A975-D (F350 DRW 8250lb springs, rumor has it they will ride like an empty 40's model dump truck)
if those aren't the right part numbers i'll change them, but i got them off another ford forum that were listed for year models up to 04.
if this is the case, say the "X" codes give apx 2-2.5", do the "B" code rears give as much or is a block needed as well?
and if a dealer only wants $200 or so per spring pack, that's not to bad. so far i've only found Skyjacker that offers separate spring for front and rear (not in a kit). i found a 4" lift spring for front/rear for $565/pair. i really don't want to go up a full 4", 2-3", with tighter handling, would be good to go!
CODE:
CODE:
All your answers are found in this thread.
https://www.ford-trucks.com/forums/789595-attn-dup-steering-wander-search-results-for-you.html
Stewart
Stewart
I think you need at least 25 posts before you can start a new thread.
change, charts, code, companies, differential, excursion, ford, front, lub, rate, recommendations, replacement, spring, springs, tcode
