Front spring replacement chart
Old Jan 10, 2010 | 03:12 PM
TeamMudd's Avatar
TeamMudd
ok i think i got this narrowed down. common upgraded front springs are
CODE:
V - Part# F81A-5310-ADB
X - Part# F81A-5310-AFA
then the upgrades for the rear are:
CODE:
B - 3C34-5560-L (6840lbs, F350 SRW, and some F250's)
C - 3C34-5A975-D (F350 DRW 8250lb springs, rumor has it they will ride like an empty 40's model dump truck)
if those aren't the right part numbers i'll change them, but i got them off another ford forum that were listed for year models up to 04.
if this is the case, say the "X" codes give apx 2-2.5", do the "B" code rears give as much or is a block needed as well?
and if a dealer only wants $200 or so per spring pack, that's not to bad. so far i've only found Skyjacker that offers separate spring for front and rear (not in a kit). i found a 4" lift spring for front/rear for $565/pair. i really don't want to go up a full 4", 2-3", with tighter handling, would be good to go!
Old Jan 10, 2010 | 07:04 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by TYZ78F150
What do I need to look for?
All your answers are found in this thread.
https://www.ford-trucks.com/forums/789595-attn-dup-steering-wander-search-results-for-you.html
Stewart
Old Jan 10, 2010 | 08:14 PM
03-6L-X's Avatar
03-6L-X
Great information.
Old Sep 23, 2012 | 07:29 PM
kajalee's Avatar
kajalee
I'm not sure how to start a new post but I'm wondering if anyone has had an issue with brakes pulling to the left and what may fix it? I know of mine and 4 others that do this. Mine has dana 60 and 70 front end and rear ends after market.
Old Sep 23, 2012 | 07:58 PM
LWW's Avatar
LWW
I think you need at least 25 posts before you can start a new thread.
Old Sep 23, 2012 | 10:05 PM
Stewart_H's Avatar
Stewart_H
Now that would be a silly rule if that were correct!
All a person has to do is click on the "New Thread" button and their very first post will be in the thread they create.
Stewart
Old Sep 23, 2012 | 11:40 PM
EXv10's Avatar
EXv10
It's probably your slide pins sticking on the non pulling side.
Old Sep 24, 2012 | 06:37 AM
TX03EX's Avatar
TX03EX
Could the pins be sticking if they are brand new?
Old Sep 24, 2012 | 10:23 AM
EXv10's Avatar
EXv10
Yes if the holes aren't cleaned out and too much lube can cause a hydro lock on them. Maybe something on one of the rotors/pads also.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
1978 - 1996 Big Bronco
May 25, 2002 03:08 PM
broom
Nov 24, 2001 12:46 PM
