Compression
Old Mar 1, 2024 | 05:19 PM
FordCardinal's Avatar
FordCardinal
Compression
Can someone please explain to me why a "lower" compression ratio is marketed to be better for pulling than a high compression ratio? I have been told many times that the older trucks for pulling/hauling had lower compression ratios. Thanks
Old Mar 1, 2024 | 05:31 PM
440 sixpack's Avatar
440 sixpack
It's not better for pulling or hauling, lower compression means less power . the reason they used lower compression was to extend the life of the engine and drive train with less power.
Old Mar 1, 2024 | 05:55 PM
6 by 8's Avatar
6 by 8
Originally Posted by FordCardinal
a "lower" compression ratio is marketed to be better for pulling than a high compression ratio. I have been told many times that the older trucks for pulling/hauling had lower compression ratios.
The people who advertised and told you that are talking out of their ar$es.
Totally agree with 440's first sentence.
Didn't know about the second sentence reasoning. I thought the lower compression was for BS emission purposes.
My engine's increase from 8.5 to 10.2 resulted in more torque and hp across the entire rpm range, and used 10% less gas whilst driving to do it !
Something tells me that more torque is more useful for pulling/hauling.
Old Mar 1, 2024 | 06:12 PM
85e150's Avatar
85e150
Lower compression was used to improve survivablity under extended loading long before it was used to reduce oxides of nitrogen.
Prior to '72 and a little later, it was not unusual to have a valve job at under 100,000 miles, sometimes earlier. (41,000 on our '66 wagon 390 2V 9.5 compression, and that was mostly before I got my license and started beating it like a rented mule)
Ahh, the good old days, with wheezer motors running low compression, single exhaust, rich carbs, and a 3 speed transmission.
Old Mar 1, 2024 | 08:57 PM
Rubiranch's Avatar
Rubiranch
The same people who told you that also believe that green is the way to go.
Like the others have said, I've never heard that either.
Old Mar 2, 2024 | 01:27 PM
1TonBasecamp's Avatar
1TonBasecamp
And it wasn’t that long ago that cylinder heads and piston tops (i.e. combustion chambers) were not that effective at reducing detonation or emissions.
So lower compressions were put in engines that weren’t meant for high performance, but more for towing and hauling and driving the kids around town.
Back then mostly only high-performance engines had compression ratios over nine something. While now it’s not even uncommon to see compression ratios of 9 and 10+ range on turbocharged engines!
So, along with better engine control systems, they can get away with a lot more nowadays.
As was often the case, they were just doing what they could, with what they knew, and with what they had.
72CC428
Sep 6, 2017 04:25 PM
smoulding
Mar 26, 2007 05:26 PM
erikl85
Nov 25, 2002 10:45 PM
