Sponsored by: Real Truck
Replacement Steering Stabilizer
Old Nov 24, 2003 | 08:29 PM
BigDawg54's Avatar
BigDawg54
which is a good replacement steering stabilizer? i want to get the rancho to compliment my FX4 package but i noticed that FabTech and SuperLift also make them. anyone have opinions on any of these upgrades? is it worth it or just worth the looks?
-bigdawg
Old Nov 24, 2003 | 08:41 PM
bedwards's Avatar
bedwards
I put the SuperLift on mine. It seems to do just fine for 1/2 price of the Rancho.
BE
Old Nov 24, 2003 | 09:00 PM
Yeti's Avatar
Yeti
All 3 are pretty much the same, nothing special, I would go with the best price.
I run a couple of rancho's, they do the job.
Old Nov 24, 2003 | 09:44 PM
Ducnut's Avatar
Ducnut
This is what I've been told by those in the know: All shocks/stabilizers that are branded by the lift kit manufacturers are generic and are produced by either Gabriel or Monroe.
My opinion is that the big heavy-duty stabilizers are too stiff for most applications. They don't allow or will too slowly allow the steering to return to center. I prefer the stock stabilizer. Having to actually return the steering to center after turns is annoying. If you're not off-roading the truck and just want the visual effect, I would just paint the stock one white, and add a Rancho sticker if you like. If the original is leaking, look for an OE takeoff.
Old Nov 25, 2003 | 01:56 PM
geraldv's Avatar
geraldv
The Rancho direct replacement part number is RS5410. It is available for $37.99 from summitracing .com and will bolt to your existing mounts. Hope this helps.
Old Dec 2, 2003 | 07:07 PM
BigDawg54's Avatar
BigDawg54
geraldv, does it come with the red boot?? the one from summit?
Old Dec 2, 2003 | 08:29 PM
geraldv's Avatar
geraldv
Yep, red boot is included along with an adapter bolt and spacer for correct fit. The whole thing is quite a bit beefer than the original. You have to call summit (800) 230-3030 and ask for it, as the RS5410 is not listed on their website. I got the model number from the Rancho application guide. Installed it in about 10 minutes.
Enjoy.
Old Dec 3, 2003 | 07:49 AM
GreatWhite02's Avatar
GreatWhite02
I second what DUCNUT said, most liftkit manufactures don't make their own shocks.What your buying is their mounts. I run a dual Superlift setup and i'm not happy with how far it hangs down. Most makers mount the same way though with the exception for the Edge. Manufactures reccommend a single for tires under 35", and a dual for tires 35" and larger.
