Injector question based on visual inspection.
Old Mar 5, 2024 | 07:29 AM
Craig Maffet's Avatar
Craig Maffet
replaced injectors 2, 3 and 7 and there is noticeable drop in diesel in the exhaust. smells like exhaust now. can't really tell by looking at them so i'm guessing spring or poppet worn. onto the low power issue w manual fuel pressure gauge.
Old Mar 5, 2024 | 10:24 AM
Craig Maffet
just goes to show, start small even if you just tested the fuel pressure. now below 40 at start before i press the pedal. two weeks ago before i pulled it out of the shop w a used motor in it, it tested at 60.
either **** on the screens in the fuel tank or the pump gone bad. don't think its air as i don't see bubbles but anything is possible i guess.
Old Mar 5, 2024 | 11:20 AM
Craig Maffet
def the tank. back up to 60 psi out of the 5 gal jug. that will learn ya kids . . start small and work your way up. make sure you have fuel and air then go from there.
Old Mar 5, 2024 | 11:27 AM
udsuth78's Avatar
udsuth78
Yep, it may seem basic, but there's a reason they are the basics.
Old Mar 6, 2024 | 06:44 AM
SkySkiJason's Avatar
SkySkiJason
https://www.ford-trucks.com/forums/1...poon-mods.html
Old Mar 8, 2024 | 08:40 AM
Craig Maffet
Update - Found the issue. You can bet this isn’t good for injectors. Pickup broke off at the quick too.
Old Mar 8, 2024 | 10:44 AM
udsuth78's Avatar
udsuth78
Well, there's your problem!.!
Old Mar 8, 2024 | 11:10 AM
Craig Maffet
lol. Got another old one similar age acting up some. Think I’ll get two rebuild kits. The little orange rubber thing - guess it’s the breather is toast. I don’t see it in any kits. Anybody know what it’s called?
Old Mar 8, 2024 | 11:16 AM
udsuth78's Avatar
udsuth78
Nope, I just took a hammer to the mixing chamber and trashed it. Ran some tube couplers and new tubing down to the bottom for the pick up, and a piece of weighted hose on the return. Add a cheap inline filter somewhere before the pump and called it a day.
Old Mar 8, 2024 | 12:11 PM
Craig Maffet
beats $300 for a new
Old Mar 8, 2024 | 12:15 PM
udsuth78's Avatar
udsuth78
Just be sure to use a good stainless steel coupling. The brass aren't strong enough to compress the ferule onto the factory tubing and it will leak.
Old Mar 10, 2024 | 07:49 AM
SkySkiJason
the solution
Skidder
Feb 25, 2012 08:21 PM
88f1504x4
Apr 22, 2011 08:11 PM
reyjav
Feb 3, 2011 05:44 PM
turboman24
Jul 21, 2007 10:34 AM
true blue
Aug 16, 2006 10:25 PM
