Hey everyone,
I am fairly new to the site so be gentle! I am getting started on a project swapping a 7.3 Godzilla and 10R140 into a 79 F-250 Super cab. I am hoping to post a build thread as I begin making progress. I have already purchased the Ford performance Power module with the motor trans and all the other cool stuff. I looked at the pdf instructions and after reading through it I found that there does not seem to be any explanation or reference as to how to access the Transmissions manual shift capabilities or the Tow Haul? I have seen where some guys have been able to get the 10r80 and 6r80's to work by adding a shifter stalk or a toggle switch. Has anyone done this with the 10R140? Any info or recommendations would be greatly appreciated. I spoke with Mars and was told that they could do it but I would need to purchase their whole control harness. I hate to spend another 3K when I purchased a "plug and play" system already form ford. I would be surprised if Ford would not allow access to this feature.
Thanks everyone
Did you find an answer to this? I am getting ready to pull trigger on buying a 7.3 and 10r140. Is it possible for you to get some measurements off the 10r140 for me? I need length from bellhousing to flange where transfer case bolts up to.
you sent a message to me but you have emails blocked so could not respond.
