Electrical problem?
Old Feb 24, 2024 | 06:35 PM
Oldblue1985's Avatar
Oldblue1985
4wd Low
Electrical problem?
So I open up the door to my 85 ford f250 in6 and cab light comes on try to start it it makes a single click sound and cab light goes off I used a multi meter to see if I'm get power to the wire that powers the truck I get power I go down to the starter and nothing I go open the truck door the light comes on then when I go to start it the cab light goes off anyone have any awnsers?
Old Feb 24, 2024 | 07:18 PM
88n94's Avatar
88n94
Remove both battery cables from their battery posts and thoroughly clean the outsides of the battery posts and thoroughly clean the insides of the battery cables. Reattach the cables and make sure they tighten up properly. This is the fix for what you describe the vast majority of the time. If that doesn't fix the problem you have to move farther down the line cleaning connections. The problem could also be a bad battery cable shorting internally.
Old Feb 24, 2024 | 08:30 PM
Franklin2's Avatar
Franklin2
If you have those repair ends on the cables, take the little bolts out and clean all that up too. You do have a dirty connection somewhere, the battery terminals are the likely culprit.
Old Feb 24, 2024 | 11:05 PM
kr98664's Avatar
kr98664
Sounds like one of your battery cables has failed. Charge your battery (very important) and then run this test to pinpoint the exact location of the failure:
https://www.ford-trucks.com/forums/1...w-starter.html
Seedguy99
Apr 1, 2022 07:58 AM
Marten
Apr 27, 2021 08:26 PM
wendal
Jun 10, 2017 11:35 PM
Full Throttle
Apr 27, 2009 11:14 PM
star
13
Mar 7, 2008 02:08 PM
