inside cab light
Old Mar 5, 2008 | 09:02 AM
star's Avatar
star
inside cab light
Is there anyway to adjust the cab light ? It takes 3-4 minutes before it turns off after I park & the cargo light is also on ? 02 F350
Old Mar 5, 2008 | 09:06 AM
guitarpicr's Avatar
guitarpicr
Dont know@ adjustment. Mine is the same way - Stays on about 1 minute.
Old Mar 5, 2008 | 09:11 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Does your door ajar light stay on while you are driving? If it does, spray your door latches real good with WD-40, closing and opening them a few times. The latch gets crud on it and the switch stops working.
Old Mar 5, 2008 | 10:58 AM
star's Avatar
star
Yes it does .Ill try that ...thanks
Old Mar 5, 2008 | 11:04 AM
HKusp's Avatar
HKusp
Thats why. When you spray the door, the light will be fixed like Rick said.
Old Mar 5, 2008 | 11:08 AM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Star, I noticed you have a 2002 model truck. Hopefully its just a sticking door switch like the other guys mentioned. But, if the spray does not work, take a look at this thread and see if you have any of these other symptoms:
https://www.ford-trucks.com/forums/4...ght=VSM+theory
Old Mar 5, 2008 | 12:15 PM
UP_There's Avatar
UP_There
WD-40 is ALMOST as good of a tool as duct-tape is
Old Mar 5, 2008 | 04:53 PM
SpringerPop's Avatar
SpringerPop
Remember the old adage:
If it doesn't move, and it should, WD-40 it.
If it moves, and it shouldn't, duct tape!
Pop
Old Mar 5, 2008 | 05:03 PM
UP_There's Avatar
UP_There
Pop
If duct tape still doesn't hold it.....JB WELD IT!
Old Mar 5, 2008 | 05:31 PM
Mike Norwood's Avatar
Mike Norwood
Pop
Gene would appreciate that Pop.
Old Mar 5, 2008 | 05:45 PM
TchTchr's Avatar
TchTchr
I like spray or powder graphite for locks and doors. Wet lubricants attract dust and gunk up the works.
Old Mar 5, 2008 | 05:54 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I think the light is supposed to stay on for a few minutes. Never has bothered me. But I've noticed if I use my remote to lock the doors the lights go out instantly.
Old Mar 7, 2008 | 12:46 PM
miller_feed
Star, did the spray work?
Old Mar 7, 2008 | 02:08 PM
star's Avatar
star
Have the diesel parked ,Im driving my F150,Ill try the WD-40 this week-end & give the results ...
