'65 T18 Shift Linkage removal
Old Feb 24, 2024 | 03:30 PM
73runner400's Avatar
73runner400
I am going to remove the 352 and T18 all together as an assembly. I am not sure how to remove the manual shift linkage. The shop manual doesn't say. Interestingly, the reprint shop manual doesn't have a T18 chapter, only T98. The truck is covered in oil/dirt everywhere and I cant really see how to separate the linkage. I don't want to man handle something and have it break. Are there any good resources or wisdom you can bestow upon me?
Old Feb 24, 2024 | 05:37 PM
john jamieson's Avatar
john jamieson
What shift linkage? The T18 is a 4speed. With the transmission in neutral, unscrew the cap from the shifter housing top. Then remove the retaining pin. The lever should lift up.
Old Feb 24, 2024 | 05:59 PM
73runner400
I guess I meant the clutch linkage.
Old Feb 24, 2024 | 06:05 PM
85e150's Avatar
85e150
Clutch linkage will be covered in grime and rust. It should have a pivot off the driver side of the bell or block, on to the top of the frame rail.
Climb under and you'll find it.
You're going to have to prevail on this to pull the engine, otherwise you will break the linkage, or the pivot, or the frame attachment, or all of the above.
Illustration:
https://www.lmctruck.com/1957-72-for...ase-components
Luch
Jan 9, 2021 03:36 PM
jonlesser
Oct 7, 2013 08:19 AM
rokford
Apr 16, 2006 10:04 PM
Mike G
Jul 19, 2004 03:45 PM
84 F250
Apr 10, 2002 05:08 AM
